Generic inks
Generic inks
2003-06-11 by Tim Timmermans
Hi everyone,
I've been away for awhile and it's good to be back. I recently had
twelve images hanging in a group show. Priced them at $225 for 16x20
and 20x20 framed and sold 7 of them. Yippee.
I am in transition between permanent dwellings and thus have not yet
set up a CIS but plan to soon. In the meantime I found a place in
South Carolina called The Ink Warehouse that sells generic inks for
Epson printers. They have a two cartridge combo (b/w & color) for the
1280 for $12.95.
Is this too good to be true? Has anyone tried any of these inks and
are they as good as the Epson brand? Clogging or fading issues?
I'm wondering if, like generic advils, and cough medicines etc that a
generic ink could be just as good as the brand name. If so has anyone
tried the ones from this company or is there another company that you
would recommend?
Also a quick photoshop question if you will indulge me. Somehow I
must have pushed a button or something but I'm suddenly getting a
little icon in upper left corner of my working images. It is an  "01"
with a little rectangle next to it. It is small and doesn't print but
it's annoying and does cover a little of the work space that I
sometimes need to access. What is this thing and how do I get rid of
it? Thanks for your help.
Thanks also to those of you who encouraged me to keep the Wacom
tablet when I threatened to return it out of frustration. I stuck
with it and I absolutely LOVE it! Thanks guys.
Tim (good to be back)
OT - PS7 Very Slow Loading
2003-06-16 by Kip Babington
Is there a common reason why Photoshop 7 should all of a sudden take an
extraordinarily long time to load, and sometimes fail to load at all?  It
was doing fine this afternoon, but this evening when I tried to open it (to
do some B&W prints using Lyson Quad Black on my Canon S9000) I've had it
fail to load several times and on another occasion took about 4 minutes to
load (felt like a half hour, of course.)
It has always taken longer to load than any other program I use, but I can
see that it loads up a ton of stuff at the start - I watch the items flash
by on the startup screen.  But this evening there are several places where
it seems to get hung up on a plug-in - I remember Bas-Relief sat on the
screen for what seemed like forever, and there were several others where
the loading process just seemed to stop for a while.  Eventually it
finished and my image manipulation seemed to work at normal speed, but
clearly something is wrong.  I didn't do anything particular to the
computer that I can remember - I just have Eudora and Internet Explorer
open most of the time.  I don't leave Photoshop open all the time, just
open it when I'm ready to do some image work.
Anything obvious to check to get back to "normal?"
Thanks for any ideas.
Kip
Re: OT - PS7 Very Slow Loading
2003-06-16 by Clayton Jones
Hello Kip,
>take an extraordinarily long time to load, and sometimes fail to
>load at all?
Have you installed any new programs?
Is your virus program up to date?
That's all I can think of.  I'd suggest contacting Adobe.
Clayton
Re: [Digital BW] OT - PS7 Very Slow Loading
2003-06-16 by Jon Dubovsky
There may be other issues beyond PS.  My laptop, for instance, has some
charming Novell drivers (read: crap) installed so I can print at the
office.  When I'm not connected to the network (i.e. the printer isn't
visible), PS seems to hang during loading and often takes several minutes
to finish.  No other programs seem to have this problem, but there is
something about how PS enumerates or checks on the printers that causes
the Novell driver to actually go out and look for 'em.  Changing default
printers didn't help.  The magic trick (ugh) is to physically disable the
network connection when PS tries to load -- it comes up in a flash -- then
re-enable it.  Of course, I'm quite sure this is all Novell's fault, and
something about PS's unusual startup behavior merely triggered it.  Note
that no other apps I have exhibit this problem.  The latest Novell drivers
seem to have almost entirely eliminated it.  It only took three years for
them to fix it.  Yay.
Jon Dubovsky ( entropy@... )
