StudioPrint Evaluation-repost
2003-06-16 by Phil Bard
All,
IÕve been working with a demo of the new StudioPrint v10 that ErgoSoft rece=
ntly made
available.  In case you didnÕt already know it is a RIP solution, designed =
for users of
wide format printers and works on a whole fleet of devices.  Among the Epso=
n models
it supports the 3000 and up, including the newer 7600, 9600 and 10600. It p=
rovides
monochromatic as well as color RIP functionality, and has built-in profilin=
g and ICC
generation features.  Monochromatic profiling is, to my knowledge, not ICC =
compliant, so soft proofing is not directly available in Photoshop. StudioP=
rint runs
only on Windows machines. See AmadouÕs previous post for further details on=
 how it
works. Following is a summary of what IÕve experienced so far on my Epson 7=
000 and
9000 printers. I will include a link to my site at the bottom of this post =
with close-ups
of scans of output and some densitometric info.  Additionally IÕve sent the=
se to
Antonis for inclusion in the Files section.
The first thing you have to do is define and linearize your inkset. I strug=
gled a little
with some things that were left out of the rather brief introductory manual=
, such as
what size paper to insert for the grayscale printouts, and how many patches=
 to
choose (10, 20 or 40).  After working for a couple hours with 20 I discover=
ed that 40
is the choice that provides best accuracy and that you need to print the ra=
mps on 24Ó
wide paper.  Also, though SP claims to be able to utilize the scan function=
 of the
EyeOne Photo to provide rapid reads of the patches, I kept getting Òwrong n=
umber of
patchesÓ errors and had to do each one individually.  This only took a few =
minutes,
however.  Additionally it took me some time to comprehend the way in which =
Print Environments are created and how the density readouts are incorporate=
d.  This
may all be detailed in the full blown manual, for which a pdf is included, =
but I only
consulted it in a piecemeal fashion so donÕt really know that yet.  However=
 from what
I did read, I felt the manual could stand some improvement. After getting m=
y head
around the process, I was impressed with the way ErgoSoft has made it possi=
ble to
create the individual Print Environments out of each set of linearizations =
per printer,
essentially copying them from previous PEÕs. As others have mentioned you c=
an
mount up any inks you want and put them in any position, SP enables you to =
selectively turn colors on and off as you choose.  This means variable and =
split toning
are possible. Also there are nice features such as drag-and-drop, the abili=
ty to group
different images and the ability to tile, position, mirror and rotate image=
s in the
layout, which are typical of RIPs, but were great to see included.  BTW, th=
is version
does not offer Postscript, which is apparently why the price is reasonably =
affordable
as RIPÕs go.
IÕve worked for a couple of years with the Cone ProRIP, and was most concer=
ned with
how SP compares to that, since the ProRIP has been dead-ended by IJM. The
proprietary dither on the ProRIP has so far been the best IÕve seen for ren=
dering detail
in carbon prints and the big question in my mind was whether SP could measu=
re up.
After trying out the Smart Diffusion dither first with less than impressive=
 results, I
linearized with the Stochastic option and found it produced much better res=
olution of
detail and virtually dotless printing. The ProRIPÕs dither has a way of eff=
ectively
sharpening up image detail while delivering all levels from 0 to 100% gray =
extremely
well.  Up close the dots have a linear arrangement, like tightly packed row=
s of
soldiers. SPÕs Stochastic dither has a more random look, like the Epson dri=
vers, and
very finely arranged.  This created a smoother look to the image when loupe=
d, with
more apparent graduations of gray, not unlike the comparison of grain in sl=
ow and
fast silver emulsions. The detail in the SP prints was almost as sharp as t=
hat of the
ProRIP, but this difference was really only visible under a loupe and may b=
e the result
of the ProRIPÕs sharpening effect.  At a distance of 12Ó both prints have e=
ssentially the
same resolution. I have to say I quite like the smooth look of the StudioPr=
int images. I
considered this issue of dither to be make-or-break for SPÉ
One thing you cannot control in ErgoSoftÕs product, nor in the ProRIP for t=
hat matter,
is how the inks are partitioned.  This doesnÕt seem to be problematic so fa=
r in
comparing the output of the two, but it is something the tweak-inclined mig=
ht miss.
One important difference with SP is that it appears to linearize to a gamma=
 that is
close to monitor gamma, which means your images will initially print very l=
ight and
with flat midtones as compared to prints from the ProRIP or the Piezo plug-=
in.  I got
an exact match from my monitor when I went into Color Settings, selected Cu=
stom
Dot Gain and left the curve in itÕs default state.  This means that straigh=
t prints of
legacy images in SP will all be way off. A workaround for this is possible,=
 however,
using the Dot Gain feature in StudioPrintÕs profile generation phase.  By a=
dding Gain
you effective raise the gamma of the profile, although how much you add can=
 only be
established through trial and error tests. Cone recommends working with 15-=
20%,
but I found 20% wasnÕt enough to darken the midtones sufficiently.  One thi=
ng IÕm
worried about is compression of the darkest levels of the grayscale as I ra=
ise gamma,
and I think IÕm beginning to see it in some of my prints.  Some of the dens=
itometer
readings support this as well and there may be a tradeoff at work here.  IÕ=
m
wondering if StudioPrint needs an adjustable Dot Gain feature, where the us=
er could
manipulate specific portions of the DG curve, like in Photoshop, instead of=
 just
specifying one amount overall.  This may mean to get the best separation on=
e would
have to go back to his scans and redo the curves, then print with less or n=
o Dot Gain
added in SP.  I have to test further on thisÉ
This is where IÕm at with this at the moment, and will post further results=
 as they are
ready.  Below is a link to some scans, you can compare the results of the t=
wo RIPs and
see some density charts showing the effects of adding Dot Gain in SP. I hop=
e this will
be of some interest to those of you looking at wide format solutions...
http://cirrus-digital.com/RIP.html
Phil
http://philbard.com
Lyson Monochrome Gloss Paper
2003-06-17 by Kip Babington
Does anyone have experience with the Lyson Monochrome Gloss or Satin
papers?  Now that I've found an affordable way (bulk/refill) to use Lyson
Quad Black inks in my Canon printer, I'm beginning to wonder about
papers.  I've been planning to use the Ilford Classic Gloss and Classic
Pearl, which are reasonably priced and available in large (250 sheet)
boxes.  But if the Lyson monochrome papers are clearly superior, either in
ink reception or tone or longevity or whatever, I'm ready to consider
them.  They do not seem to be available in the US, at least not that I can
find, and unlike the bulk inks, Marrutt doesn't ship paper from England for
free unless you buy a lot of it.
  So - - - - - any experience with it out there?
Thanks for any help.
Kip
