Re: [Digital BW] MIS Ultra-tone inks
2003-06-19 by Edward Wiseman
Jeff..
MIS has their "NEW" Ebony for the black position that should cure any fading
problems you may have had with the "original" black psition co-solvent ink
in your VM set-up..I am using VM Sepia now which uses the same black, and
I'm now in the process of switching to the Ebony..I haven't heard any
"definitive" third party statements on the "Ultra-Tones" as of yet..
Eddie Wiseman
To: "digital bw group" <DigitalBlackandWhiteThePrint@yahoogroups.com>
Sent: Thursday, June 19, 2003 6:22 PM
Subject: [Digital BW] MIS Ultra-tone inks
> Hey Everyone;
> Does anyone know what the status of the MIS ultra-tone inks are? On the
> MIS web site they are still listed as "experimental" and only available
> in bottles. I would like to buy a set in carts to give them a try.
> I did make some nice prints with the VM set...printing mostly with the
> medium warm and warm curves. However, after these prints where exposed
> to indirect light for a short time they warmed to great degree... much
> MUCH greater then the moderate increments of the medium warm -vs- the
> warm curve. For me that does not make this inkset usable. I have heard
> that when printing with the more neutral curves or cool curves the
> prints do not warm much.
> -Jeff
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
page.
them short.
> - Good manners are required at all time. No personal attacks or flames
resources on the homepage.
RE: [Digital BW] MIS Ultra-tone inks
2003-06-20 by BOB KRAMER
Jeff, you might consider buying the small 2 oz. bottles of the Ultratone
inks and a set of virgin cartridges.  It won't cost you much more than a set
of preloaded carts, and they are quite easy to load yourself.  This inkset
is great!  Much better than the original quad and VM inks that I had been
using previously.  You really should give them a try.
Bob
Sent: Thursday, June 19, 2003 6:23 PM
To: digital bw group
Hey Everyone;
2003-06-20 by dirkhobman
I have been using the Ultratone inks for some time now and have found
them to be a significant improvement over the old VM inks. I print
with an 1160 printer and generally use semigloss papers. The
following are my experiences with these inks:
1) There is nothing comparable for black and white printing on
semigloss or glossy papers. Forget about Piezography. The old VM inks
required an overcoat spray to prevent rubbing off. This is no longer
a problem with the new Ultratone inks. Personally, I have yet to see
a digital black and white print that looks even remotely as good on a
matte paper as on a semigloss paper. Typically, comparisons of the
same image printed on a matte paper vs. a semigloss paper (with the
appropriate black of course) leave the image on the matte paper
looking extremely flat and muddy. I suppose this must appeal to some,
but I have been surprised that more individuals do not seem to have
been bothered by the inability of black and white inks to print on
semigloss or glossy papers. The Ultratones now give this flexibility.
I have had most success printing on Pictorico's Premium Photo Glossy
Paper and Epson's Professional Glossy Paper (reasons noted below).
2) Unlike the old VM inks, the Ultratones do not seem to have even
the slightest problem with clogging. I am using the photo black in
cartridges (not a CFS yet) and I have yet to experience a single
issue with clogging. I have left the inks sitting in the printer
unused for well over a month and been able to start printing without
a head cleaning (or at most just one). I should note that I live on
the Front Range in Colorado at 5000 feet and am in an extremely dry
climate. The old VM black caused so many clogging problems in this
climate that I eventually had to replace a head on my printer.
3) The new curves Paul has made for the Ultratones on the 1160 are a
significant upgrade over the old VM curves. I had puddling problems
with the old VM curves and the new Ultratone inks. The new curves
solved this issue. Not only that, but they lay down less ink and
consequently result in markedly improved image quality with smoother
transitions on the grey scale (Note that all of this pertains
particularly to my experiences printing on semigloss paper. I am sure
the same would hold on matte or glossy papers however). On semigloss
papers, there are now absolutely no visible dots in higlights on the
1160. It's quite impressive. This was not the case with the old
curves and the VM inks. In general, my experience has been that
printing on glossy or semigloss papers is considerably more demanding
from the system as a whole than printing on matte papers. Matte
papers seem to smooth out any imperfections, whereas semigloss and
glossy papers readily show any weaknesses - be it in the printer not
having perfectly clean heads or the inks not being perfectly
linearized etc.
All this said, areas for improvement with the Ultratones might be as
follows:
1) The new curves for the 1160 are just about perfect on matte paper.
They will need some adjusting on glossy/semigloss papers. I have
found there to be a large jump between 100% and 95% that can be
visually distracting. I have yet to fix this. Paul is ultimately much
more qualified to deal with this than I am.
2) Bronzing is apparent on some glossy or semigloss papers. I found
there to be some distracting reflectance issues with the Ultratones
on some papers. It is not horrible, but it can be an issue. The
reason I print on the Pictorico paper and the Epson Professional
Photo paper is that these two papers seem to almost completely
eliminate this problem. (I should note I'm still experimenting with
other papers at this time.) Epson Premium Semigloss seems acceptable,
but not quite as good in this respect when compared with the two
aforementioned papers. Premium Luster does not fare quite as well. I
would encourage you to experiment for yourself if interested.
All in all, I highly recommend these inks. They are a vast
improvement over the old VM inks, and Paul and MIS deserve much
credit for their hard work and effort and for providing this system
at such a reasonable price.
Dirk Hobman
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, BOB KRAMER
Ultratone
than a set
inkset
had been
> Regards,
> Bob
> From: Jeff Magidson [mailto:jef.jef@v...]
> Hey Everyone;
available
exposed
much
heard
2003-06-20 by Alan Zimmerman
Dick, Having processed fine art prints in a chemical darkroom for over 30 years, I felt exactly the same shortcoming of digital printing on matt papers vs gloss or semi gloss. In my digital printing I have used Epson premium semi gloss, and lustre , with GP inks and just ordered my first batch of Ultratone inks I'm  very interested to know where to buy Pictorico paper.
Alan Zimmerman
  Sent: Friday, June 20, 2003 9:24 AM
  Subject: Re: [Digital BW] MIS Ultra-tone inks
  linearized etc.
  follows:
  Dirk Hobman
  Ultratone
  than a set
  inkset
  had been
  > Regards,
  > Bob
  > Hey Everyone;
  available
  exposed
  much
  heard
        Yahoo! Groups Sponsor
2003-06-20 by Jeff Magidson
> Ultratone
> a set
> inkset
> been
> Regards,
> Bob
Bob, Dirk and Paul:
Thanks for your info and encouragement! I will give the Ultra-Tones a
try.
-Jeff
2003-06-20 by Jack M Kucy
Alan,
I was listening to all of these discussions and I am convinced already
to the
Ultratone inks.  I am setting up for BW right now, so I have one more
question.  I read that Ultratone inks work well with the Epson driver, and
this would be the cheapest solution.  What other software (RIP) should I
consider for improving the printing process - working on Pc? Or it's not
worthy the effort.  I heard so much about the dot gain control and so on.
I would appreciate the advice.
Jack
_________________________________________________
Jack M Kucy
JMK Gallery (www.jmk-gallery.com)
917-991-2096     jmk@...
Member of ASMP (www.asmp.org)
...a riveder le stelle
> Thanks,
> Alan Zimmerman
>   linearized etc.
>   follows:
>   Regards,
>   Dirk Hobman
>   Ultratone
>   than a set
>   inkset
>   had been
>   > Regards,
>   > Bob
>   > -----Original Message-----
>   > Hey Everyone;
>   the
>   available
>   the
>   exposed
>   much
>   the
>   heard
Jack,
I have not yet received the ultratone shipment so haven't had a chance to print. However, I plan to use Paul Roarks work flow on my PC and epson 1280 and the curves listed in the MIS software chart. At present, there is no curve listed for the 1280 and ultratone, but I understand that the ultratone curve for 1160 will work well.I have not tried any other workflows or curves so unable to list alternate choices yet.
Alan
  Sent: Friday, June 20, 2003 12:03 PM
  Alan,
  to the
  Jack
  Jack M Kucy
  > Thanks,
  > Alan Zimmerman
  >   linearized etc.
  >   follows:
  >   Regards,
  >   Dirk Hobman
  >   Ultratone
  >   than a set
  >   inkset
  >   had been
  >   > Regards,
  >   > Bob
  >   > Hey Everyone;
  >   the
  >   available
  >   the
  >   exposed
  >   much
  >   the
  >   heard
2003-06-21 by Chris Hargens
I know this is for the most part a matter of taste, but I'd like to
hear what others have say about the difference between matte and
glossy papers. I say this not to provoke an argument but to better
understand the merits of each kind of paper.
Chris Hargens
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dirkhobman"
found
inks
longer
see
a
some,
flexibility.
Glossy
without
a
smoother
sure
semigloss
demanding
not
> linearized etc.
as
> follows:
paper.
much
acceptable,
I
> Regards,
> Dirk Hobman
> Ultratone
> than a set
This
> inkset
> had been
> > Regards,
> > Bob
> > Hey Everyone;
On
> the
> available
with
> the
> exposed
> much
> the
> heard
2003-06-21 by Truman Prevatt
The makers seem to have the secret for making good high quality matte
papers that give consistent results that are pleasing to view and that
have no major warts.
On the other hand that doesn't seem to be the case with glossy. Until
this is the case I will stick matte. We are probably a year or two off
yet and the so called "bornzing" may always be with us since it has as
much to do with higher ink loads in dark areas than light areas.
I'd like to see a glossy paper of comporable of say photo rag, EAM,
etc., and if one comes out I will try it.
Truman
>Chris Hargens
