Re: [Digital BW] CFS-Air in tubes
2003-06-24 by Martin Wesley
From: "jimenez12fr" <miguel.jimenez@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Tuesday, June 24, 2003 7:25 AM Subject: [Digital BW] CFS-Air in tubes > Hello, > > I've just installed a CFS system from MIS on an Epson 1290 printer > with VM quadtones. I had problems with the vacuum filling method (I > managed somehow to break to vacuum pump provided by MIS) and in the > end I used the bottom filling method to fill the cartridges. I > inserted a syringue at the bottom, breaking the seal, connected the > tubes to the ink bottles and started pulling the syringue until I > got some ink in it. It worked fine, and it prints well, but shortly > afterwards I saw that the tubes are filled with air in long parts of > it close to the cartridge. The section of the tubes next to the > bottles have ink in them. I've made only 4-5 prints so far. > Question: Is the air going to damage the system? I fear that the > printer is using the ink in the cartridges, but once it starts > getting air inside everything will be messed up. Anyone had this > problem before? Should I refill the cartridge, and how could I do > it? Pulling all the ink and air with a syringue until I have a lot > of ink in it? > > Sorry for this naif question in the middle of so high tech > discussions here. Like many, I follow them with interest trying to > understand what's going on. Thanks in advance. > Jimenez, I've botched the vacuum fill myself a couple of times and the bottom fill method does the job just fine. Don't worry about the air in the lines. Just go ahead and start printing. The lines will fill up quickly and you will not harm the printer. As you print or do a nozzle check you should see the air in the lines move as ink flows from the bottles. Happy printing! Martin Wesley
