New UT curves for 1280 - downloaded
2003-07-01 by Jack M Kucy
I seem to have a problem with the new curves.  I downloaded them, tried to
follow all instructions and when I print the gray wedge using  UT80-N I
can't
get consistent neutral gray across the wedge.  Some areas are very blue
(60-90)
and the other very worm (with the pick about 25-35). I might have been doing
something completely wrong or... I got no idea.
I did even an experiment and printed the wedge (converted to RGB) which
I "color balanced" with magenta (to activate the cool ink) as follows:
shadows 0, -5, 0;  mid tones 0, -15, 0;  highlights 0, -10, 0.
It gave me wedge print of nice, consistently neutral gray.
Can anyone summarize the workflow with these curves?
I would appreciate that.
Thanks
Jack
_________________________________________________
Jack M Kucy
JMK Gallery (www.jmk-gallery.com)
917-991-2096     jmk@...
Member of ASMP (www.asmp.org)
...a riveder le stelle
Paul Roark wrote:
> >Can you by chance point me to a download site for your
> >new 1280 Ultra Tone curves?
> The curves are in the Files section of this forum at:
> Files > Ink Sets > MIS > MIS Ultra Tone Inks
> Paul
> http://www.PaulRoark.com
RE: [Digital BW] New UT curves for 1280 - downloaded
2003-07-01 by Paul Roark
The new 1280 Ultra Tone curves use the same basic workflow as the old vm
curves (edit in grayscale, save file, convert file to RGB, apply curves, and
print).
They, of course, were written for the Ultra Tone B&W inks, not the old MIS
VM inks.
There are significant differences in settings.  The new curves use "No Color
Adjustment" in the driver color management section.  This disables the
sliders but makes the curves cross-platform.  Also, the RGB type should be
Adobe RGB (1998). (This is set in Edit, Color Settings;  I set all to PS5
defaults and then just change RGB to Adobe (1998).)
The paper setting is Photo Paper, and the resolution should be 1440.
As before, these curves were written for EAM/EEM.
Let me know how it goes.
Sent: Monday, June 30, 2003 11:38 PM
Subject: [Digital BW] New UT curves for 1280 - downloaded
can't
(60-90)
Thanks
Jack
Jack M Kucy
> Paul
page.
them short.
resources on the homepage.
Re: [Digital BW] New UT curves for 1280 - downloaded
2003-07-01 by mccarvill
FWIW, I'm using your 1280 VM curves with UT on Pictorico Photo
Gallery Glossy and Brightcube Glossy (paper setting = premium glossy,
color management = off), with very nice results (thanks, Paul!). I
have to print at 2880, however, to eliminate banding. And I'm still
looking for a way to eliminate those annoying pizza wheel marks
(suggestions welcome on that one).
I tested the 1280 UT neutral curve along side the VM neutral curve,
but the UT-curve half of the print was much colder (had a bluish
cast) and there was some slight banding present (test also done at
2880).
Might a curve made for printing UT on glossy paper at 2880 produce
significantly better results and, if so, is that on your to-do list
by any chance?
Mark
old vm
curves, and
> print).
old MIS
> VM inks.
use "No Color
should be
to PS5
> Paul
> From: Jack M Kucy [mailto:jmk@j...]
tried to
N I
> can't
blue
> (60-90)
been doing
which
follows:
> Thanks
> Jack
> Jack M Kucy
> 917-991-2096     jmk@j...
> > Paul
Polls and
wish to
this same
> page.
to keep
> them short.
header.
flames
various
RE: New UT curves for 1280 - downloaded
2003-07-02 by William B. Strong, Jr.
Paul,
Do these settings also apply to the new 1160 UT curves? I am
replacing my VM CIS with a new UT CIS.
Bill
________________________________________________________________________
Message: 4
    Date: Tue, 1 Jul 2003 08:14:14 -0700
Subject: RE: New UT curves for 1280 - downloaded
print).
VM inks.
RE: [Digital BW] RE: New UT curves for 1280 - downloaded
2003-07-02 by Paul Roark
Bill,
The new 1160 UT curves use Adobe RGB (1998) and No Color Adjustment, but
leave the paper type HW Matte.
Message: 4
print).
VM inks.
page.
them short.
2003-07-03 by mike rott
>Paul
Paul,
I downloaded your new curves for the 1280 and UT inks and gave then a
quick try this evening. All I can say is wow! These are some of the
nicest B&W prints I have made so far, very smooth tones. These inks
and curves are a real winner. I really want to thank you for all your
efforts designing the inkset and making the curves. Your generosity
in freely sharing your hard work and talent I find remarkable, and it
is greatly appreciated.
Thanks.
By the way, I have been in the process of moving (just bought my
first house) over the last few weeks and the UT inks have been
sitting in the printer about 4-5 weeks boxed up. After unpacking, I
went to make my first print today using the new curves and did an
initial nozzle check. Perfect nozzle check, no clogs.
mike rott
Re: New UT curves for 1280 - downloaded
2003-07-03 by c2c_ic
I agree with Mike,
 Thank u Paul 4 all yur work n efforts. They r appreciated and u r
very generous with both yur work and yur time. You have helped me on
many occasions, i know. best regards always Paul.
                      Tim
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, mike rott
> >Paul
> Paul,
a
your
it
> Thanks.
> mike rott
