Lyson Print Guard or Krylon Kamar on Hahnemühle WT?
2003-07-02 by Derrick
Hi, has anyone used lyson print guard or kamar varnish on Hahnemühle William Turner paper before? I'm looking for some coating which i can apply to the paper to prevent/reduce scuffing or flaking of the paper. So far only lyson print guard and krylon "Kamar" varnish seems to be available here in singapore. I've read some posts mentioning applying hydrocote with a mayer rod to matt papers as a good solution but these aren't available here. Thanks Derrick
2003-07-02 by Roger L Sopher
Hi Derrick, I have used Krylon Workable Fixativ and Krylon UV Resistant Clear. I suspect that any of the fixatives designed for pastels might do. Roger
Sent: Tuesday, July 01, 2003 11:37 PM
Subject: [Digital BW] Lyson Print Guard or Krylon Kamar on Hahnemühle WT?
Thanks
Derrick
Yahoo! Groups Sponsor
ADVERTISEMENT
page.
them short.
resources on the homepage.
[Non-text portions of this message have been removed]2003-07-02 by johngeyles
> I have used Krylon Workable Fixativ and Krylon UV Resistant Clear. I suspect > that any of the fixatives designed for pastels might do. So, does anyone know what all these various sprays and coatings that are proposed here will do to print longevity ? Obviously they provide protection to the paper and inks themselves, but what about the longevity of the spray coating itself ? Seems like yellowing and possible cracking could be a serious issue and reduce the effective life-time of the print well below what good pigment inks on an acid-free paper would otherwise allow. I realize that increasing longevity is probably not the main reason people apply coatings - rather it's to increase DMax, in the case of Hydrocote PUR on matte papers, or to reduce bronzing, in the case of the Kamar and Lyson products on RC papers. But is it worth it, if longevity suffers ? Just a thought, John
Hi John, The products produced for the pastel trade are considered "archival" and are used to stabilize those fragile surfaces. I don't recall the source at the moment but I recall reading that museum conservators routinely coat pastels with such sprays. My wife, a professional artist, uses them a lot when she is working with pastels. Paul Roark has posted a number of experiments he has done with print coating with a number of products and if my memory serves me correctly ran archival tests as well. I printed a pair of step wedges on a number of papers and sprayed one with whatever I was testing and left the other dry. After a couple of weeks in the New Mexico sun I found very little change in the densitometric readings, particularly the paper white; so as far as that crude experiment goes it doesn't seem yellowing due to the coating is liable to be a problem. The downside to their use in my view is the fairly unpredictable darkening of the black pigment. The dmax will increase but the darker grays do so as well and it isn't completely linear. I got so that I could predict how a particular print would act and then adjust in photoshop so that the sprayed version looked pretty much as I wished it to but it is hit or miss to some extent. I finally decided it wasn't worth the effort even though it did protect the surface nicely. Now if I get a flaked off spot I return to the ancient darkroom method of hand spotting - argghhhh.... Roger
Sent: Wednesday, July 02, 2003 12:36 PM
Subject: Re: [Digital BW] Lyson Print Guard or Krylon Kamar on Hahnemühle
WT?
suspect
ADVERTISEMENT
page.
them short.
[Non-text portions of this message have been removed]2003-07-02 by John Vitollo
> So, does anyone know what all these various sprays and coatings > that are proposed here will do to print longevity ? Try this interesting page: http://www.livick.com/method/inkjet/pg2a.htm
2003-07-02 by Paul Roark
> So, does anyone know what all these various sprays and coatings > that are proposed here will do to print longevity ? Here is what one authority said: Ross Merrill, Chief of Conservation at the National Gallery of Art, Washington D.C. (USA), in a 1997 speech regarding pastel conservation said as follows regarding fixatives: "Today there are a number of alternatives. Krylon Acrylic Varnish B72 is used by conservators. This product will remain unchanged for 400 years, but does have a tendency to saturate the surface. Grumbacher B77 varnish or "tough film" is the same as B72, but will not saturate. Krylon workable fixative and Sennelier fixative are both good products. One should stay away from Grumbacher's "blue label" fixative." See <http://www.bmi.net/knapp/iapsmerrill.html> Rohm & Haas's Acryloid/Paraloid B72 formula is widely accepted as archival, if for no other reason than it has been around for a long time. Although Krylon's B72 is not available any more (probably since Sherwin & Williams bought the company and decided not to pay royalties), some of the Krylon products may be very close to it. Grumbacher "Tuffilm" is widely available at art stores and not too expensive. Lascaux Fixativ is the real B72 but is rare and expensive. Krylon is the cheapest of the bunch, from what I can see. In my fade tests, a light acrylic coating has had no significant effect. If applied heavily, I find the dynamic range of the print to be shortened. We can never be sure what interactions may occur over the long haul, but my feelings are that a light spray may be a good idea for physically protecting the pigments somewhat from abrasion. Paul http://www.PaulRoark.com
2003-07-05 by Derrick
Thanks for all the replies. Krylon products aren't in stock till next month over here. The only fixative for pastels that i found and bought in the art supply shop was Daler-Rowney Perfix Colourless Fixative for Pastels. I've tried spraying 1 print. What do i look out for to see that its working or providing better protection for the surface? There does not seem to be any noticable difference. I probably need to get a face mask. A few whiffs of the spray and i was feeling a bit woozy. Derrick --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roger L Sopher" <rlsopher@c...> wrote: > Hi Derrick, > > I have used Krylon Workable Fixativ and Krylon UV Resistant Clear. I suspect
> that any of the fixatives designed for pastels might do. > > Roger
2003-07-05 by Antonis Ricos
> I've tried spraying 1 print. What do i look out > for to see that its working or providing better protection for the > surface? Derrick, you can test for abrasion after the coating has dryed. Better yet, you can make two prints, coat one and put both in the sun and then watch what happens. If you have a densitometer, take readings of the white, black and some gray midpoints and see if they shift over time in a different manner for the coated vs uncoated prints. > I probably need to get a face mask. A few whiffs of the spray and i > was feeling a bit woozy. Not to make light of it, but if you are in Singapore there should be plenty of those around. Seriously, don't breathe the stuff. Work outside if you can because the spray may remain suspended longer than you think (unless you have a spray booth with active exhaust ventilation). If you can find a satisfactory way to coat by rod or foam brush, choose it over spray. We have had extensive discussions on all this here, so maybe you can dig up some info in the list archives. Antonis
