2200/OPM extreme sepia profiles
2003-07-03 by Antonis Ricos
I have uploaded two profiles to make extremely warm sepia prints with the 2200 using OPM. You can find them in our Files section inside the IJC/OPM folder. These have been made for EAM paper and the matte black (MK). They produce a respectable 1.71 dmax. Since the white of that paper clashes so much with the warm sepia, I would advise that you tint the paper in a separate pass using these profiles and a tint anywhere from 5-20% (tint-to-taste, the three Ts of toning). Anyone with IJC can have fun using these as a basis to produce variations, of course. For the record: the automatic linearization feature of IJC was NOT used for these since it doesn't distinguish between gray and toner inks. They were linearized "by hand" to within +-0.01 of the aims. Of course, that may only hold true for my printer and only on that day!... These do use a fair amount of yellow ink along with magenta in the mix - in case anyone has concerns about either metamerism or longevity. They were initially made to match a vintage print that was being restored - which gives you an idea of the kind of tone I was after. There are 2 profiles: One ends with _xSEP_01.6 and is the "normal" profile - marked with an x for extreme sepia (!) . The other marked _xSEPy1_01.6 is marked with a y1 to indicate increased yellow. I was going to make variations with even more yellow, but found that I was already in overkill territory. These two together can be blended nicely in OPM to fine-tune the degree of yellow. Just in case anyone is in the mood for that extra-antique look!.... Antonis
