IJC linearization demonstration
2003-07-05 by Antonis Ricos
To demonstrate the effects of linearization in IJC, I have uploaded an Excel
graph that shows three plots:
- the "aims", which are the ideal densities for the given dmin and dmax (.05 to
1.69 in this case). These are generated internally by IJC once the readings of
the unlinearized print are entered.
- the unlinearized plot which shows how far from the aims the initial ink curves
are. The idea is to show that a simple, approximate "throwing together" of
some curves, is a good enough starting point (yes, within limits, but without
worrying about accuracy across the scale).
- the linearized plot which shows the effect of the internal calculations of the
program once the readings for each of the 26 gray patches was entered. The
near perfect plot means that all the initial "sloppiness" is removed
automatically in one step by the linearization engine of IJC.
Some caveats and limitations:
- This particular excercise was done with a profile that uses small amounts of
LightCyan and LightMagenta in the 2200 to neutralize the extra warmth of the
gray. In theory, I should have turned off these tinting inks while linearizing,
and then turned them back on - sort of cheating the linearization a bit.
Because in this case they add very little density, the effect is inconsequential.
However, when it comes to major color shifts (such as in my earlier sepia
profiles), I abandon linearization alltogether so I can compensate for density
independently  of color. The linearization engine presently does not
distinguish between the two.
- This demonstration was based on readings of relatively "fresh"  prints: They
were dried with a hair dryer and read within approximately the same time after
they each came out of the printer. Any dry-down effects are thus equalized.  It
so happens that the OEM inks of the 2200 dry to a pretty stable density
relatively quickly. But that is not the case with all inks.
The FS black, for example, takes almost a day to reach final density on Photo
Rag. This throws a "curve" (pun intended) to the linearization engine. I find it
more reliable to linearize manually (by precise moves on the curves of the
inks) and plot the results in Excel anticipating the final drydown. Most of the
difficulty comes from the very short and steep curve required for the black to
kick in at the end of the scale. Of course, that's assuming I want to chase down
every little + or - 0.01 deviation from the aims. In most cases, you can get
close enough to print - but it's a caveat worth bearing in mind.
In general,  it's a good idea to have a sense of what a given deviation from the
aim densities does to a real image: If you have the subtlest of gradations
across a sky (or a skin tone), the smallest deviation will break it. If you have a
rough grainy image with many abrupt variations of grays, you'll hardly see a
+- 0.04 error.
The other little dark secret in all this chasing down of the perfect gray scale is
that all those "cheap densitometers" we often talk about here (like the XRite
810) have a whole lot more accuracy in the shadows than they do in the
highlights. Nothing wrong with the instruments, they are just missing an extra
decimal point. When it comes to densities less than 0.10, there is only one
digit to work with. Shadows get the benefit of 3 digits. Given the log nature of
the scale, that results in a fairly rough read of the highlights. Going after that
extra decimal, however, could cost thousands. So, we after "good enough"
here - a reality check to keep in mind!
Since it's been a while since IJC has been released, I hope these
observations are useful to those making profiles with it.
Antonis
Re: IJC linearization demonstration
2003-07-06 by Roy Harrington
Antonis,
I enjoyed your description of the IJC linearization and the issues found.
I don't own a 2200 but Carl Schofield has done some work on the curves
for it using QuadToneRIP.  During that, we also ran into the issues of
adding light-cyan and light-magenta to neutralize the tone.  In fact I think
trying to compensate for the added density was the major effort in the
cool curve.  Carl also had some nice plots of density. See:
http://harrington.com/QTR-2200.pdf
I see you did some sepia curves lately, did you notice much metamerism
in those prints?   All along the yellow ink seems to have been blamed
for metamerism -- I wonder how true that is.
Roy
RE: [Digital BW] Re: IJC linearization demonstration
2003-07-06 by Daniel Staver
A while back I tried replacing the yellow cartridge with a light black
cartridge to see what the result would be. I printed a few grayscales
and they turned out bright purple, which means that the Epson driver
must be using very large amounts of color to make its neutrals. So I
think the metamerism could simply be a result of the amounts of colors
used in general, not the yellow in particular.
I also tried a few BW prints using the MIS 7600 Archival color inkset in
my 2100. That's their version of the UltraChromes. Those prints also had
metamerism, but different. The prints shifted much more towards blue
than towards green, and the metamerism was just a little bit less severe
with that inkset (but nothing to get excited about).
Making sepia-toned prints have been a common workaround to avoid the
metamerism with the Epson driver, which doesn't really spport the theory
that the yellow is particularly bad.
Daniel Staver
http://daniel.staver.no
Re: [Digital BW] Re: IJC linearization demonstration
2003-07-06 by Carl Schofield
I also found Antonis's  linearization tutorial very informative and
helpful.  I haven't seen any metamerism in sepia prints I've made using
IJC/OPM or QTR profiles that employ K, LK, LM, and Y inks only with
very small amounts of the yellow and light magenta used for toning.
Perhaps the metamerism is more dependent on ink load, rather than just
the yellow ink.
Carl
On Sunday, July 6, 2003, at 02:37  AM, Roy Harrington wrote:
> Antonis,
> found.
> think
> Roy
> Save on Coral Calcium. Get Better Health and
> Stronger Bones. Seen on TV
> http://www.challengerone.com/t/l.asp?cid-2805&lp=calcium2.asp
> http://us.click.yahoo.com/9gf46B/EfUGAA/ySSFAA/ucIolB/TM
> Please visit the Group Homepage to check the Files, Bookmarks, Polls
> and other resources as they are often being updated. The page is at:
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> - As the topic of a thread changes remember to change the subject
> header.
> - Good manners are required at all time. No personal attacks or flames
> - Before posting a question, search the message archives and the
> various resources on the homepage.
> Your use of Yahoo! Groups is subject to
Carl,
That's what I was thinking.  If there's no problem using all the light inks
sparingly, then you could have an ultimate B&W printer -- Matte Black,
Photo Black, Light Black, and a Very Light Black for the gray inks.  This
gives you 4 grays for matte paper and 3 grays for glossy.  Then you have
a light C,M and Y for any toning you like.  Just a thought.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield <scho@m...>
> the yellow ink.
> Carl
> > Antonis,
> > found.
> > think
> > Roy
2003-07-07 by Antonis Ricos
Roy,
I saw the spreadsheet - seems like some midtones went adrift between the
cool and the warm. Yeah... separating color from density will be the next
challenge in designing monochrome drivers.
As for my sepia curves - they are sooo sepia that metamerism doesn't have a
chance to enter the equation.  IOW the gray is so flooded in yellow orange that
a slight shift wouldn't turn it green or magenta. The problem seems to be
when you are trying to hold neutrals out of primaries. In my case, I base the
scale on the grays and then start "pumping" yellow and L. magenta reducing
gray desnity just enough  to compensate (mostly for the density of the
magenta plus whatever the densitometer makes of the yellow under its
"visual" setting - which is a whole other  can of worms).
As for your load order with the 2200: I agree except for loading the two blacks
at the same time. Seems like a waist of a position since these carts are so
easily changed back and forth (unless you use a CIS). But otherwise, yes: we
only really need an extra light gray to get a full grayscale, the equal of a
dedicated bw printer. Beyond that, its tone city!
The only theoretical reservation is whether toning by adding dots of primaries
is inferior to using toned gray inks (i.e. sepia. cool etc). Both on account of
permanence and visually where the eye has to synthesize the dots (e.g.
highlights).
But, as I said.... these are theoretical issues. I am currently getting a beautiful
chocolate warm print with "golden" highlights by a 50:50 blend of a neutral
and a sepia profile and then hitting the whole thing with a 5% tint of the sepia
"tinting profile". The tint is masked to preserve the highlights.
Antonis
> Antonis,
> Roy
