No way of using 2200 two blacks only...?
2003-07-18 by Andre Vallejo da Silva
It's funny that no one has came out with a profile,or a RIP setting for using the black and light black of the 2200 to bw print...probably it could get almost as good as the 3 inks evereyone says is enough for it... Anyone aware of developments in this regard? Isn´t it possible to write a curve that follow this idea?
2003-07-20 by Peter Nelson
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Andre Vallejo da Silva" <avs@p...> wrote: > It's funny that no one has came out with a profile,or a RIP setting > for using the black and light black of the 2200 to bw > print...probably it could get almost as good as the 3 inks evereyone > says is enough for it... > Anyone aware of developments in this regard? Isn´t it possible to > write a curve that follow this idea? There IS a way but last I checked it was only available for Mac and Linux systems. Anyway, the "light black" on the 2200 is really a sort of sepia color - it's not gray.
2003-07-20 by Harry Saddler
I have an Epson 1280 with an MIS CIS loaded with VM inks. I let the thing sit for too long between uses, and now the black (K) jets won't print. I did the usual unclogging tricks, with no success. Then I tried sucking ink from the bottom of the cart with a syringe... and it feels like something's plugged: the plunger goes right back when I let it go. Then I pulled the feed tube off the top of the cart, and stuck a syringe on that, pulled back; nothing, just a total vaccuum that pulls the plunger back when I let it go. Would I be right in guessing that the tube's plugged? Anyone else seen this? Harry
2003-07-20 by Bob Michaels
I found the diagnostic evaluation steps and fixes on the MIS website to be excellent. I followed them once and found that I did have a permanent clog in the black ink feed line. Even with the line removed from the cart, I never could clear it and replaced the line. Bob Michaels --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Harry Saddler" <hsaddler@p...> wrote: > I have an Epson 1280 with an MIS CIS loaded with VM inks. I let the thing > sit for too long between uses, and now the black (K) jets won't print. I > did the usual unclogging tricks, with no success. Then I tried sucking > ink from the bottom of the cart with a syringe... and it feels like > something's plugged: the plunger goes right back when I let it go. Then I
> pulled the feed tube off the top of the cart, and stuck a syringe on > that, pulled back; nothing, just a total vaccuum that pulls the plunger > back when I let it go. Would I be right in guessing that the tube's > plugged? Anyone else seen this? > > Harry
2003-07-20 by Doug Fisher
I have had some stubborn clogs but have always been able to get them to break loose. Are you using the large 60cc syringe? The small ones just don't create enough vacuum. I would max out the vacuum and hold it for 30 seconds, then do a couple of quick pull and releases on the syringe and then hold again for 30 seconds at max vacuum. Things eventually broke free. Doug
2003-07-20 by John Vitollo
I've seen this tube clogging with the orignal Piezography inks. It's the inks seperating forming sludge in the tubes. You could probably clear it with an agressive use to the syringe. But I would pull off all the tubes and soak it in warm soapy water.
2003-07-20 by ed021us
I had the same problem and tried all the same things. The quickest way is just replace the black tube cut it off and leave it in the bundle and tape a new tube in the bundle. God luck Ed Blake www.edblakephotography.com -- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Harry Saddler" <hsaddler@p...> wrote: > I have an Epson 1280 with an MIS CIS loaded with VM inks. I let the thing > sit for too long between uses, and now the black (K) jets won't print. I > did the usual unclogging tricks, with no success. Then I tried sucking > ink from the bottom of the cart with a syringe... and it feels like > something's plugged: the plunger goes right back when I let it go. Then I > pulled the feed tube off the top of the cart, and stuck a syringe on > that, pulled back; nothing, just a total vaccuum that pulls the plunger
2003-07-22 by Mark Hahn
the black tubes clog. I had them send me some extra tubing and I just remove that tube, replace it and suction through and keep going. A bit of a hassle, but workable. mark --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Harry Saddler" <hsaddler@p...> wrote: > I have an Epson 1280 with an MIS CIS loaded with VM inks. I let the thing > sit for too long between uses, and now the black (K) jets won't print. I > did the usual unclogging tricks, with no success. Then I tried sucking > ink from the bottom of the cart with a syringe... and it feels like > something's plugged: the plunger goes right back when I let it go. Then I > pulled the feed tube off the top of the cart, and stuck a syringe on > that, pulled back; nothing, just a total vaccuum that pulls the plunger
