T008 ink position
2003-07-23 by Richard Vanek
Hi, I am just refilling and realize that i do not know position of inks in epson T008 color cartridge, even the original do not have it. I can't find it on MIS site for T008. help! Thanks!
Hi, I found this on paul workflow page at MIS web. Is it true for T008 as well? "When viewing the cartridges that are installed in the printer, an Epson 4 color printer is K,C,M,Y from left to right. An Epson 6 color printer is C,LC,M,LM,Y from left to right" --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Richard Vanek" <richard.vanek@e...> wrote:
> Hi, > > I am just refilling and realize that i do not know position of inks > in epson T008 color cartridge, even the original do not have it. I > can't find it on MIS site for T008. > > help! > > Thanks!
2003-07-23 by Paul Roark
Richard, >I am just refilling and realize that i do not know position of inks >in epson T008 color cartridge, even the original do not have it. I >can't find it on MIS site for T008. The MIS instructions are at http://www.inksupply.com/index.cfm?source=html/virgin110.html >I assume that parking pads are bellow cartridges on right >side. Small sponge looking rectangle on plastic container on springs? >(epson 890) Yes. Rotate the wheel at the left to release the carriage, and move it out of the way and you can get to the pads fairly easily. Water or a very dilute water/ammonia solution should do the trick. Paul http://www.PaulRoark.com
Paul, Thank you for your response, excuse my writings and questions, I am just completely excited! I was waiting for this moment (and the moment I'll print first few photos) quite some time and I was shocked when it arrives 6 days after order when I expected at least 2, 3 weeks. > The MIS instructions are at > http://www.inksupply.com/index.cfm?source=html/virgin110.html Yep, I did it acording that procedure, it was suprisingly easy. Unfortunately there is no T008 picture on any page of MIS, I am affraid. I followed information from your workflow page. Hope it is all right. I was a bit suprised that it went that easy and also MIS on that page writes 10cc for color chamber. Sometimes I had 11cc and it went in with no problem. Do I need to reset chip before I put cartridge in printer? Will be indication of amount ink left correct? Can I trust epson monitor when it indicates change? > Yes. Rotate the wheel at the left to release the carriage, and move it out > of the way and you can get to the pads fairly easily. Water or a very > dilute water/ammonia solution should do the trick. Thanks! I'll do pads cleaning tomorrow before I'll put new filled cartridge in. -richo- http://piskoftak.sk/
Richard, >> The MIS instructions are at >> http://www.inksupply.com/index.cfm?source=html/virgin110.html >Unfortunately there is no T008 picture ... The ink order is the same on all Epson hextone carts, I assume. >Do I need to reset chip before I put cartridge in printer? If the cart was new, there is no need to re-set the chip. >Will be indication of amount ink left correct? Can I trust epson >monitor when it indicates change? Epson is conservative. If the right amount of ink was put in the carts, the monitor will say you are out before that actually happens. (I think there is a lawsuit in Europe alleging Epson is cheating customers by this practice. Epson's response is that running the printer head when it's dry damages the head. So, it's better to leave some ink in the cart.) Happy printing. Paul http://www.PaulRoark.com
2003-07-26 by Ed Mathews
Is there a website someone can suggest that might have basic
information on methods of coating and protecting prints? Specifically,
I'm printing with my Epson 1280 on Matte paper and just a drop of water
causes the ink to run and ruins the whole print. Is there something I
can spray that will not dramatically ruin the tones of the image but
still protect it? I tried some Krylon acrylic fixative (which I use for
my homemade diffusion filters), and it just soaked into the paper,
ruined the print, and did nothing to protect it.
Right now I'm using the Epson inks, as this is my 3'rd 1280 under
replacement (finally got a good one), but when these run out I'll
probably be MIS archival ink.
I've seen many references hear to coatings using rods and whatever,
but I have to admit I just don't understand that process at all (is
there a primer out there somewhere?). Spraying something would be a
much easier way to get started for me.
It seems to me that some kind of clear adhesive backed laminated
sheet would be a good solution, but I suspect there's nothing like that
out there that's archival in nature.
All suggestions and information is appreciated.
Ed
http://lightandsilver.com2003-07-26 by markroth61
See this thread...it should answer your question; I was just looking at it and found it very helpful: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/295 41 Mark R. (Avoid Krylon "Preserve-it!" The can makes tempting claims "archival, doubles the life of the print, etc.", but leaves a rough texture on the print. I am returning a can on Monday to the art store.) --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ed Mathews" <ed@l...> wrote: > Hi, > Is there a website someone can suggest that might have basic > information on methods of coating and protecting prints? Specifically, > I'm printing with my Epson 1280 on Matte paper and just a drop of water > causes the ink to run and ruins the whole print. Is there something I > can spray that will not dramatically ruin the tones of the image but > still protect it? I tried some Krylon acrylic fixative (which I use for > my homemade diffusion filters), and it just soaked into the paper, > ruined the print, and did nothing to protect it. > Right now I'm using the Epson inks, as this is my 3'rd 1280 under > replacement (finally got a good one), but when these run out I'll > probably be MIS archival ink. > I've seen many references hear to coatings using rods and whatever, > but I have to admit I just don't understand that process at all (is > there a primer out there somewhere?). Spraying something would be a > much easier way to get started for me. > It seems to me that some kind of clear adhesive backed laminated > sheet would be a good solution, but I suspect there's nothing like that
> out there that's archival in nature. > All suggestions and information is appreciated. > > Thanks, > Ed > http://lightandsilver.com
2003-07-27 by markroth61
Whoops...the message wrap broke up the link...it's message 29541 http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/295 41 --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "markroth61" <mark80905@h...> wrote: > See this thread...it should answer your question; I was just looking > at it and found it very helpful: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/295 41 > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/295 > 41 > > Mark R. > > (Avoid Krylon "Preserve-it!" The can makes tempting claims "archival, > doubles the life of the print, etc.", but leaves a rough texture on > the print. I am returning a can on Monday to the art store.) > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ed Mathews" > <ed@l...> wrote: > > Hi, > > Is there a website someone can suggest that might have basic > > information on methods of coating and protecting prints? > Specifically, > > I'm printing with my Epson 1280 on Matte paper and just a drop of > water > > causes the ink to run and ruins the whole print. Is there > something I > > can spray that will not dramatically ruin the tones of the image but > > still protect it? I tried some Krylon acrylic fixative (which I > use for > > my homemade diffusion filters), and it just soaked into the paper, > > ruined the print, and did nothing to protect it. > > Right now I'm using the Epson inks, as this is my 3'rd 1280 > under > > replacement (finally got a good one), but when these run out I'll > > probably be MIS archival ink. > > I've seen many references hear to coatings using rods and > whatever, > > but I have to admit I just don't understand that process at all (is > > there a primer out there somewhere?). Spraying something would be a > > much easier way to get started for me. > > It seems to me that some kind of clear adhesive backed > laminated > > sheet would be a good solution, but I suspect there's nothing like
> that > > out there that's archival in nature. > > All suggestions and information is appreciated. > > > > Thanks, > > Ed > > http://lightandsilver.com
2003-07-27 by Ed Mathews
Thanks. I'll hit an art supply store and see if I can find one of the things listed. Thanks, Ed http://lightandsilver.com
> -----Original Message----- > From: markroth61 [mailto:mark80905@...] > Sent: Saturday, July 26, 2003 8:20 PM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: [Digital BW] Re: Coating/protecting matte paper > > Whoops...the message wrap broke up the link...it's message 29541 > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/295 > 41
