Re: Imageprint for B&W
2003-07-26 by grdglass@aol.com
There is no metamerism with ImagePrint for B+W.
> IMHO, ImagePrint may give you a great B&W print with a 2200 (or 7600/9600
> for that matter) but metamerism will rear its ugly head in different
> lighting situations and your 'neutral" B&W print will only be neutral in a
> narrow range of lighting conditions.
Metamerism and bronzing are not the same thing.  Metamerism is the change of
overall color under different lighting.  The entire B+W print would appear
greenish under daylight and magenta-ish under tungsten.  Bronzing produces a
"shine" on only dark areas of a print because of differing ink laydown properties.
You see bronzing with manipulating the print at various angles to the light.
Metamerism is seen "straight on."
Helene
>>I wonder if we're all talking about the same thing. My understanding is
that
metamerism and "bronzing" are the same, i.e., a printed image viewed from an
angle (usually), displays a metallic-like bronze-tone in the darker ink
areas,
creating an almost posterized or negative image in the worst case.
Chromaticity
(as it explained to me by the Cone Editions lab manager) is when ink reflects
differing coloration, depending on the viewing light source... the coloration
usually being crossovers such as magenta or green. If I'm incorrect, please
don't hesitate to set me straight.<<
2003-07-27 by grdglass@aol.com
Chromaticity is a synonym for hue.  Maybe the lab manager used that word to
describe the effect (a change in hue), not the phenomenon (metamerism).
Helene
> Where does "chromaticity" come in?
>>Chromaticity
