Re: [Digital BW] Re: coating again
2003-07-30 by Jack M Kucy
For 8x10s I used EEM but the stock is a bit thin.  Again, for this this
paper didn't have
time to buckle when absorbed water from the coat.  I even didn't have to
tape the bottom.
I wouldn't try it for the bigger size.  I print up to 13x19.  The rod I
ordered has 20" of the
wired length so I put the paper sideways, tape the longer edge, and go.
I used a few Red River Paper products.  My best pick being 65 lb Red
River Premium Matte
(244 gsm - 12 mil).  They have even thicker paper which reproduces well,
 but it's a bit too
yellow for my taste.  I  haven't tried yet any of the acclaimed
Hahnemühle papers, but
probably I will end up with them doing my next show.
Hope it helps,
Jack
_________________________________________________
Jack M Kucy
JMK Gallery (www.jmk-gallery.com)
917-991-2096     jmk@jmk-gallery.com
Member of ASMP (www.asmp.org)
...a riveder le stelle
claudej1@... wrote:
> In a message dated 7/30/2003 1:22:26 PM Pacific Daylight Time,
> DigitalBlackandWhiteThePrint@yahoogroups.com writes:
> > From: Jack M Kucy <jmk@jmk-gallery.com>
> > Subject: Coating - again...
> > Hi Group,
> > After running MIS UT CFS on my 1280 for a while I decided to
> > finally to use my custom made 26 inch Mayer Rod (20" wire wound).
> > I wasted 2 test prints, since my table was a bit tilted and the
> > Hydrocote Polyshield was moving to the right while applying.
> > When I fixed that the prints are amazing.
> > I use UT with photo black, but after coating with Satin Polyshield
> > they look like good Ilford FB glossy - air dried.  I love it.
> What paper did you use?
> Claude
