Re: [Digital BW] 1200 clog still there
2003-08-07 by bgs
You might have a bad cart. I use a CFS....MIS-VM and did have similar type of problem early in the year. You can run separate squares of each "color" by putting in the numerical value for each color separately and printing. If they are not the same as a swab taken from the bottle, the color cart might be split inside. This is what happened to mine.Bought a new unfilled color cart from MIS, filled it and it has been fine ever since. These carts will fail sometimes. I was getting irregular nozzle checks also at that time. Did you run a purge pattern?......bgs P.S.: I still only use warm water on the pad and on folded Bounty if need be. It was a promise I made to the owner of the service center. I might be the only Windex bolter! ----- Original Message ----- From: "Stephen Kobrin" <skobrin@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Thursday, August 07, 2003 8:27 AM Subject: [Digital BW] 1200 clog still there > I put windex on the pad yesterday and left it overnight. There is > some improvement, but the "yellow" ink is still badly clogged and > some of the others show problems during a nozzle check. The wierd > thing is that the nozzle pattern got worse after running a cleaning > cycle. I have just put a second application of windex on the pad. > > If this does not do it, what is the next step. I have found two in > various places: 1) remove the carts and squirt windex directly into > the "feed tubes;" or 2) reinstall original Epson carts and see if > that cleans things out. Unfortunately my orignal Epson carts have > been sitting for almost a year, so that means I would have to buy at > least the color cart, as the black seems fine. > > I really can't complain since this is the first time since I swiched > to quad inks last October that I have had a serious problem. > > Any help appreciated. > > Steve > > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or flames > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various resources on the homepage.
> > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
