UltraTone Sepia hexset?
2003-08-16 by Editor P.O.V. Image Service
Paul or anyone else... Any thoughts about a UT based replacement to the VM-S inkset? -- "Just some guy," and caretaker of the Multiverse's largest EPSON printer User Community (highly recommended by Vogon Poets and MegaDodo Publications), at: http://groups.yahoo.com/group/EPSON_Printers/ "For the rest of you out there, the secret is to bang the rocks together guys"
2003-08-16 by Paul Roark
Keith,
How strange you should ask.
Note that, I believe, a dual-toner rip is or should be out soon. Once there
is individual control of the jets, a hextone machine can tone both
directions -- cool and sepia. The Bowhaus system is probably going to be
able to do this.
Also, I've made a UT-Sepia toner (that MIS has) for this and for quads. On
quads this makes a UT-vm-s that goes from warm (UT base ink) to sepia --
which, to me means a dedicated sepia print that I'm not going to bother
with.
I do think the Epson driver might support a state-of-the-art vm-s up-grade,
and I have started down that path already.
Since I'm still most interested in matte papers, I'm thinking of an
Eboni-based, matte-paper-only neutral/selenium gray based ink. Eboni is
less warm than the UT black inks. As such less color pigment is needed to
make it into a neutral-toned ink. I just did some initial fade testing on
an Eboni-based cyan-position ink. It did very well indeed. In past initial
testing Eboni black has beaten all the competing black inks I've tested on
matte paper. So, this black with less color pigment should make a superior
neutral ink -- and an excellent base gray for a new vm-s. ("Eboni-VM-S"?)
I'll probably change the variable-tone approach for my current hextone
printers (1280 and 7500). I'll do some testing on my 1160, but for the next
VM-S, I'm leaving quads behind. (It's been good.) There will be new
densities, so the old curves will not work. The 1280 and 7500 are the only
drivers I'll support. (They appear to be useable in the 1290, 7xxx and
9xxx machines.)
These plans are somewhat vague, but that is the direction I'm migrating.
http://www.PaulRoark.com2003-08-16 by c2c_ic
Hi Paul,
As you know, I'm interested in the selenium and cool/neutral b&w
prints so i'm very interested in the UT inks in this regard. I use a
1280 and am just waiting for the UT inks to b offered in the pre-
filled cartridges. Your comments about a selenium hexset is of great
interest. I'm not into this commercially so the 1280 printer is just
fine 4 my purposes. Most of my images wud work well with a selenium
tone or a cool/neutral look.
Did u ever have the opportunity 2 try the UT inks on a canvas paper?
I've asked this group a couple of times but no one seems 2 b using
canvas paper at all. Thanks for yur patience and help.
Tim
DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
<paul.roark@v...> wrote:> Keith, > > You wrote: > > >Any thoughts about a UT based replacement to the VM-S inkset? > > How strange you should ask.
Tim, >... I'm interested in the selenium and cool/neutral b&w >prints so i'm very interested in the UT inks in this regard. I use a >1280 and am just waiting for the UT inks to b offered in the pre- >filled cartridges. MIS should have 1280 carts in a week or so. I recommend 1280 users stick with carts for a while. > Did u ever have the opportunity 2 try the UT inks on a canvas paper? No. Paul http://www.PaulRoark.com _____________________________ DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...> wrote: > Keith, > > You wrote: > > >Any thoughts about a UT based replacement to the VM-S inkset? > > How strange you should ask. Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - Include your full name with your message. - Include the address of your website, if you have one. - As threads develop, trim off excess portions of earlier messages to keep them short. - As the topic of a thread changes remember to change the subject header. - Good manners are required at all time. No personal attacks or flames - Complete your Yahoo profile. - Before posting a question, search the message archives and the various resources on the homepage. Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2003-08-16 by Jack M Kucy
Paul Roark wrote: > > MIS should have 1280 carts in a week or so. I recommend 1280 users stick > with carts for a while. > > Hi Paul, Where is the catch? I was researching the options for a long time before I got my MIS CIS UT set for my 1280. Should I understand that I would be better off if I didn't go for the CIS option. Could you elaborate a bit on it? I would appreciate that. So far I am happy with my system running with your curves. Should I expect any problems? Thanks, Jack _________________________________________________ Jack M Kucy JMK Gallery (www.jmk-gallery.com) 917-991-2096 jmk@... Member of ASMP (www.asmp.org) _________________________________________________ ...a riveder le stelle
Jack, >> MIS should have 1280 carts in a week or so. I recommend 1280 users stick >> with carts for a while. > >Where is the catch? I was researching the options for a long time >before I got my MIS CIS UT set for my 1280. >Should I understand that I would be better off if I didn't go for the >CIS option. Could you elaborate a bit on it? The current approach works very well and will, I assume, be out there for some time. The catch is that there are some otherwise "good" RC papers that are too warm in the shadows; the current toner is not strong enough to cool them down. I may brew a stronger toner that will be able to deal with these warm shadow areas. Quads and the older hextones really can't take a stronger toner without showing dots. However, the 1280/90 can. So I may make a special UT-1280 toner set that can deal with those warm RC papers. This should not affect the availability of the current UT toner, which I will continue to use in my 7500. Paul http://www.PaulRoark.com
Thanks for clearing it out. Jack Paul Roark wrote:
> Jack, > > >> MIS should have 1280 carts in a week or so. I recommend 1280 users > stick > >> with carts for a while. > > > > >Where is the catch? I was researching the options for a long time > >before I got my MIS CIS UT set for my 1280. > >Should I understand that I would be better off if I didn't go for the > >CIS option. Could you elaborate a bit on it? > > The current approach works very well and will, I assume, be out there for > some time. > > The catch is that there are some otherwise "good" RC papers that are too > warm in the shadows; the current toner is not strong enough to cool them > down. I may brew a stronger toner that will be able to deal with > these warm > shadow areas. Quads and the older hextones really can't take a stronger > toner without showing dots. However, the 1280/90 can. So I may make a > special UT-1280 toner set that can deal with those warm RC papers. This > should not affect the availability of the current UT toner, which I will > continue to use in my 7500. > > Paul > http://www.PaulRoark.com >
2003-08-17 by Editor P.O.V. Image Service
Paul Roark wrote: >Note that, I believe, a dual-toner rip is or should be out soon. Once there >is individual control of the jets, a hextone machine can tone both >directions -- cool and sepia. The Bowhaus system is probably going to be >able to do this. > > > Not to mention the potential money Bowhaus could make by releasing a utility allowing users to run cleaning cycles on the individual jets that might be clogged - they could make a mint off the latter simply by allowing end-users to clear clogs without wasting tons of ink Imagine a scenario where you print a Bowhaus nozzle check patter and then simply tell software in the driver to clear those jets.. The savings in ink could be immense over the standard cleaning cycles.. Not to mention that if it was implemented to purge onto paper running through the machine, instead of onto the cleaning pads, you wouldn't increment the damn "self-destruct" counter of the printer.. If you know the folks at Bowhaus and they haven't considered this, feel free to forward the suggestion to them.. "Just some guy," and caretaker of the Multiverse's largest EPSON printer User Community (highly recommended by Vogon Poets and MegaDodo Publications), at: http://groups.yahoo.com/group/EPSON_Printers/ "For the rest of you out there, the secret is to bang the rocks together guys"
And an "Eboni-VM-Se" (since 'Se' is the atomic symbol for Selenium)?
>9xxx machines.)
And the 1280 driver seems to be usable on the 1270 and perhaps even
2000P's as well..
Publications), at:
guys"2003-08-17 by Paul Roark
initial
superior
Yes, the neutral gray would be a VM-Se, of sorts.
The cyan will probably be the same density as the current VM and Piezo/FS
cyans, so it would also be easy to make one of those inksets from the new
Eboni-Selenium cyan. I'll use the standard, readily-available clear base
from MIS and will probably publish the formula so that all will be able to
have a rock solid neutral inkset. There is a dual source for Eboni (aka
Cone Museum, from what I can tell) so that consumers should not have to
worry about paying excessive rent to any seller. Anyone who can develop
film will, I hope, be able to make this rock solid inkset for very little
cost.
Even though I'll probably make new toners for the 1280, the existing sepia
toner will probably work on the new base gray ink. So, all the printers
that run or can run the current vm-s will be able to benefit from an
improved base gray ink.
http://www.PaulRoark.com2003-08-17 by B. Alex Pettit Jr.
Hi Paul, How about a Selenium set for 4 color printers aka Epson 3000, or the formula for making such, please ! Best, Alex > > >Paul Roark wrote: > > >>Since I'm still most interested in matte papers, I'm thinking of an > >>Eboni-based, matte-paper-only neutral/selenium gray based ink. Eboni is > >>less warm than the UT black inks. As such less color pigment is needed to > >>make it into a neutral-toned ink.
Alex, >How about a Selenium set for 4 color printers aka Epson 3000, >or the formula for making such, please ! I suspect that will also result from the mixing effort. Once you've done a few of these and get the tones right in the cyan position ink, the rest of the positions are simple. I have enough graphs that one data point and extrapolation based on the appropriate graph of similar inks usually hits within the mixing tolerances. Paul http://www.PaulRoark.com __________________________ > > >Paul Roark wrote: > > >>Since I'm still most interested in matte papers, I'm thinking of an > >>Eboni-based, matte-paper-only neutral/selenium gray based ink. Eboni is > >>less warm than the UT black inks. As such less color pigment is needed to > >>make it into a neutral-toned ink. Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - Include your full name with your message. - Include the address of your website, if you have one. - As threads develop, trim off excess portions of earlier messages to keep them short. - As the topic of a thread changes remember to change the subject header. - Good manners are required at all time. No personal attacks or flames - Complete your Yahoo profile. - Before posting a question, search the message archives and the various resources on the homepage. Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
