--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "yumeg_15237"
<yum@p...> wrote:
> I tested Gregory Schern recommendation as to converting RGB to B&W.
> In step 1 when New Hue/Saturation Adjustment Layer is created, and
> Lightness is put to +100, then the image disappear-you can see only
> white frame, which is natural. All further steps do not change
> situation. Maybe I do not understand something? Yume
I just looked at his setup. Are you changing the Layer mode to
Saturation? That should work, hope that helps.
matt betea
