1160 terminal problem??
2003-09-07 by Reinier van der Ryst
I removed the head from my 1160 because the black and cyan heads were
completely blocked. I backsucked windex and finally warm distilled water
through the heads over a number of days. Finally I dried the head with a
hair drier periodically over a period of one hour. I re-installed the head,
oiled the head guide and switched on. Problems!!!
The head moves against the little white tongue, to the left of the head, but
it does not get pulled down. Then the two ink lights (left two lights) come
on and stays on. Then the power light and the paper feed light start
flashing at one second intervals. (I reset the the waste pad counter also
but it makes no difference.)
If I pull the white tongue down before switching on, the two ink lights come
on, the head moves about four cm to the left, stops, moves left nearly to
the end, stops again and the slams violently against the left stop. Then the
power and paper feed lights start flashing at one second intervals.
The printer is about three years old and has had about sixteen ounces of
black and eight ounces of each of the VM-S inks through it.
What can I do - retire it and get a 1290? Or what?
Reinier
