Re: [Digital BW] Re: Nikon Coolscan 800 120 film holder
2003-09-12 by Ernst Dinkla
Sent: Friday, September 12, 2003 5:21 PM
Subject: [Digital BW] Re: Nikon Coolscan 800 120 film holder
> Hi Ernst,
> I'll try the Vuescan with the 8000, but 2 final quick
questions -
> 1) Do you see much image quality difference between regular and
fine scan
> when using Nikon scan?, and
I don't see the difference till there's banding in one of the
scans.
But due to shortcomings in the Nikonscan software I mainly scan
with Vuescan that only does the fine scan.
> 2) Do you use the glass holder you have buy seperately, or just
the regular
> holder that comes with the scanner?
This one:
http://members.chello.nl/e.dinkla/MF_FM_carrier.htm
Ernst
2003-09-13 by Ernst Dinkla
Sent: Saturday, September 13, 2003 8:02 AM
> on 9/12/2003 5:39 PM,
DigitalBlackandWhiteThePrint@yahoogroups.com at
> DigitalBlackandWhiteThePrint@yahoogroups.com wrote:
> > Message: 4
> > Date: Fri, 12 Sep 2003 15:21:57 -0000
> > From: "nick90290" <NickBrandt@...>
> > Subject: Re: Nikon Coolscan 800 120 film holder
> > Hi Ernst,
questions -
and fine scan
just the regular
> > Thanks
> > Nick
Bruce, you wrote:
> I see the difference between regular and fine scan in more
images than I'd
> like.  It pops up when scanning low contrast negs like c-41
films after one
> brings them up to normal contrast.
You mean the appearence of banding or a general difference in
image quality ? You mention the low contrast in relation so I
guess it is the first. Banding will be different per scanner as
it is a result of the 3 uncalibrated sensors. I probably had some
luck with mine as others have more often reported similar
problems.
> I tried the regular holder and reluctantly bought a glass
holder which works
> much better.
It is the first step that brings most of the quality gain. What
you also could check is the focus at the left and the right side
of the carrier. By adding some tape over the full length
underneath one of the bars at right or left the focusing can be
be improved over the entire image. I had to do that for three
8000 scanners and all were lower at the left side. It is
interesting though that the focus in the middle will always be
lower than the sides, probably related to the lens curvature.
That was all measured for the wetmount carriers that I made.
Ernst
