I've been setting up the print, under "page set up" in the "Print with Preview" area as one
of the gimp print printers (without using the quadtone for this part), and then setting up
the quad tone RIP printer under "Print." This allows me to use the quadtone curves, but
the pages come out centered.
Sarah
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington" <roy@h...>
wrote:
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dawhol9" <jrhone@m...>
> wrote:
> > > Unfortunately, the centering code is based on the printable area not the
> > > paper itself. So it's unaware of the uneven margins. It should be consistent
> > > though. So figure out how much you need to nudge an image up/down or
> > > left/right and it should be always the same. Also it's different for portrait versus
> > > landscape setups.
> > > Roy
> > So...If I change the margins using the custom margins by the same amount...It will
> be
> > fine? This is basically what I have done and I have a custom size for a landscape
> and
> > a custom for portrait in each paper size.
> > John
> I've never tried it but it sounds like a good solution.
> Thanks.
> Roy
