Epson 1280 and FS inks
2003-09-13 by jim21tet
After a one year hiatus, I am going to try B&W printing again with
my old stock of FS inks.  A long time ago Paul Roark recommended the
following alternative ink to cartridge positions.  My question
is "Has this system ever been validated?" or am I better off with
the normal cartridge ?illing.
Thanks in advance
Jim
If you want to use FS inks with a hextone machine, you have three
choices.
First, buy a Piezo driver. Second, buy a ColorByte ImagePrint 4 RIP
(check
with that company first). Third, change the ink positions and
(maybe) write
some simple curves. (Since I do not have a hextone machine, I have
not been
able to test this and have not been able to write the curves --
which may
not even be necessary.)
Here is the alternative FS-Hextone-Epson-driver ink positions I
recommend.
It is based on the following observations. First, the light inks
tend to be
about 60% of the density of the full strength inks. Happily, the
FS/Piezo
magenta is almost exactly 60% the density of the cyan ink. Second,
current Piezo/FS ink mix is actually too light, being designed for
the old
quad machines. As such, radical curves are needed to control it.
These
curves leave artifacts and destroy grayscale. Thus, a darker ink mix
should
be better.
So, the alternative FS ink mix for the Epson driver is as follows:
Black -- Use the MIS FS (or VM) black;
Cyan position -- Use FS cyan-position ink;
Light cyan position -- Use FS magenta-position ink;
Magenta position -- Use FS cyan-position ink;
Light magenta -- Use FS magenta-position ink;
Yellow -- Use FS yellow-position ink. (The FS magenta-position ink
may work
here also. I'd test both of them.)
This proposed FS-Epson-Driver inkset can probably be controlled
either by
mild partitioning inks or just a simple grayscale workflow. It might
print
rather well with no workflow at all.
I think there is a very good chance that the FS inks in the above
positions
in a 1280 or 1290 will produce the best B&W print possible, beating
all
current workflows -- Piezo software included. I hope someone will
give it a
try and let us know how it works.
Re: Epson 1280 and FS inks
2003-09-13 by Shilesh Jani
Jim,
I have been using this method for over a year now.  Even though I
have the Piezo Plug-In, I prefer the method outlined by Paul.
Indeed, it requires just a mild curve to linearize when printing from
a grayscale file.  I have found that for the Eclipse Satine papers
(if they are still available), there is no curve required at all.
Please note:  I use the FS yellow postion ink for the yellow position.
If you look at Clayton Jones' recent evaluation of a technical
exchange prints, my print was #9.
Many forum memebers have seen my prints using this method, and are
free to chime-in about the prints (good or bad).
Good luck.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jim21tet"
> Thanks in advance
> Jim
> choices.
> (check
> (maybe) write
> not been
> which may
> recommend.
> tend to be
> FS/Piezo
> the
> the old
> These
mix
> should
> be better.
> may work
> either by
might
> print
> positions
> all
> give it a
RE: [Digital BW] Epson 1280 and FS inks
2003-09-13 by Paul Roark
Jim,
I have a couple of curves in an "FS-Hex" folder that might work with that
proposed FS-hextone ink position.  I think some one tried the ink position I
recommended, but I don't recall the details.
Frankly, I'd recommend you just go to the Ultra Tone inkset if you have a
1280 and want to do B&W.  The UT inks are more lightfast than the FS inks.
But, if you want to use up your old inks, I'd be happy to send the curves I
have.
http://www.PaulRoark.com
_________________________________
Sent: Saturday, September 13, 2003 8:38 AM
Subject: [Digital BW] Epson 1280 and FS inks
Thanks in advance
Jim
choices.
(check
(maybe) write
not been
which may
recommend.
tend to be
FS/Piezo
the old
These
should
be better.
may work
either by
print
positions
all
give it a
page.
them short.
resources on the homepage.
