Re: [Digital BW] Medium format scanners con't
2003-09-28 by Anthony Atkielski
> I'm looking for a film scanner to handle 6x9 Delta 3200 negs.
> From what I've read, the Nikon 8000 has a shallow depth of field
> and the glass neg carrier would most likely be needed.
If your film is reasonably flat, you can get good results from the standard
MF carrier.  I switched to the glass carrier mainly because my film was
often not very flat, and because mounting film in the standard carrier is
kind of awkward compared to the glass carrier.
