thanks, but I was really looking to do something like this:
http://www.kcbx.net/~mhd/2photo/outneg/outneg.htm
mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Jon Dubovsky
<entropy@i...> wrote:
> > anyone using quadtone prints as contact sheets? The biggest
proplem
> > I'm having with my MIS-VM/1160 setup is getting my blacks...
seems
> > like a contact sheet and proper exposure would get that out of a
> > quadtone print... anyone doing this?
> Yes, I use my Epson 1280 with MIS-VM for all of my B&W contact
sheets
> these days. With my Epson 2450 scanner I can scan 3 strips of 6
(35 mm)
> negs or uncut slides in one shot. I lay them up, hit "scan" on
Silverfast
> (at 720 dpi), go start dinner or whatever... come back in fifteen
or
> twenty minutes, lay up the next three strips and repeat. When it's
done,
> I have two big images in Photoshop, I run a recorded action to cut
out all
> of the space between the strips and paste them together into one
file. I
> can then save the 30-some megabyte file.
> At this point, I can be in a hurry and print them out at 720 dpi (a
> standard 8" x 9" contact sheet) with some USM'ing, or I can let PS
resize
> upward a bit before USM'ing and printing. The latter option may
sound
> odd, but I find that if I eat up all the paper I can (620 dpi gives
me a
> 10.5" wide sheet), the slightly bigger images are much easier to
proof.
> That 15% may not sound like much, but it works for me. YMMV.
> The system is so low-effort and effective (and darkroom-setup-
saving... a
> premium at my new house) that I'm going to start using it for color
> contact sheets. I've done a similar contact sheet scan for both
color
> negatives and color transparencies, and it just as easy with the
exception
> of having to take one minute to set the color balance properly.
> As for getting the blacks right, I don't have a problem with it.
> Silverfast's pre-scan of the first lay-up lets clearly see where my
black
> and white points are. It takes me all of ten or fifteen seconds to
drag
> the black and white point sliders to the right points before I
hit "scan."
> I leave it alone (i.e., use the same settings) for the second set
of strips.
> Best of luck.
> Jon Dubovsky
