WOW!!!!!!!!!!! Thanks!!!! Those curves change everything! I've
been fighting with the original curves for 2 years and had just come
to accept that some images just could not be successfully printed in
quadtone... one of the hardest ones that I had been working on just
yesterday printed perfectly first try with the new curves!!!
Yeah!!! Hats off to Paul!!!
mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Andrew Unger"
<ungram@y...> wrote:
> Mark, I'm assuming that you are using the original VM inkset and
> original Roark 1160 curves. I switched to the new curves designed
> for the Ultratone VM inkset but am still using the original VM and
> found a great improvement because the new curves have a smooth
> transition. The shadow problem is no more. Reprinting some old
> favorites has shown how much better the new curves are. The toning
> works just fine with the new curves too. The new Ultratone VM set
> will probably give even more improvement. You can find the curves
> and instructions in files/MIS/Ultratones/1160. Remember to use "no
> color adjustment" in the print dialog for color management. - Andy
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mark Hahn"
> <markhahn2000@y...> wrote:
> > I have been using the MIS-VM inkset with Roark curves and find
> that I
> > am exclusively shooting warm or medium warm ink... doesn't seem I
> > really need the variable inkset and while I am generally happy
> with
> > the results, shadows are often a problem. Do the Original or FS
> > inksets give better shadow details? If so, what
curves/workflow?
> > Opinions on best results?
> > thanks,
> > mark
> > PS I recognize that I am asking for opinions only...
