QTR: relinearizing an existing curve
2003-10-16 by David Wroblewski
Roy, could you confirm that this is the right procedure for
re-linearizing a curve that already has LINEAR="..." data,
such as the one Carl sent me this afternoon:
(1) Edit the .txt file and comment out the existing LINEARIZE="..."
line. Verify CALIBRATION=NO.
(2) Process and install the curve with quadprofile/quadcurves
scripts.
(3) Print out 21Step.tif using the curve of interest
with Output Mode=Quadtone Rip, *NOT* Quadtone Rip Calibration.
(4) Measure the patches and add result to the .txt file as a
LINEARIZE="..." data, then reprocess and install the result,
(5) Reprint 21Step.tif to make sure you got a sensible result.
David
Re: QTR: relinearizing an existing curve
2003-10-16 by Roy Harrington
Looks perfect to me.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "David Wroblewski"
> scripts.
> Thanks,
> David
Okay, thanks. It seemed like it had to be right, but I wanted
to make sure.
Just did it: works great!
-david
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy
> Roy
Wroblewski"
LINEARIZE="..."
> > scripts.
> > Thanks,
> > David
2010-04-04 by William
Can the procedure below be done with a densitometer? So the LINEARIZE="..." data will be in density not LAB?
Jon
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "David Wroblewski" <dawroblewski@...> wrote:
> scripts.
> Thanks,
> David
2010-04-04 by igor_mountain
Yes, it can, QTR supports both.
Igor
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "William" <agiprop@...> wrote:
> Hi,
> Jon
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "David Wroblewski" <dawroblewski@> wrote:
> > scripts.
> > Thanks,
> > David
2010-04-05 by William
Thank you, Igor, amazing how hard it is to find out this info!
Jon
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "igor_mountain" <igorkarpenko@...> wrote:
> Igor
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "William" <agiprop@> wrote:
> > Hi,
> > Jon
> > > scripts.
> > > Thanks,
> > > David
