Piezo blugin with MIS Full Spectrum Neutral Inkset
2003-10-27 by Johnny Eades
I am using the Full Spectrum Neutral inkset from MIS and the George
Woolf curve on the MIS website. I have PiezoBW that contains the
plugin but have not used it because of the inkset used with the
George Woolf curve. That inkset can be used with the upcoming new
upgrade of PiezoBW which uses ICC paper profiles. Well, today I
decided on a whim to print an image with the plugin using the WRONG
INKSET JUST TO SEE WHAT WAS DIFFERENT and the resulting print shows
much more of the tonal range of the image than the curve designed for
that particular inkset. If I am so pleased with these results, then
how much better can the upgrade be than the plugin? The inkset
mention is the FSN Hextone (Epson Driver used).
Your friend in photography,
Johnny Eades
RE: [Digital BW] Piezo blugin with MIS Full Spectrum Neutral Inkset
2003-10-27 by Martin Wesley
* -----Original Message-----
* Sent: Monday, October 27, 2003 9:22 AM
* To: DigitalBlackandWhiteThePrint@yahoogroups.com
* Subject: [Digital BW] Piezo blugin with MIS Full Spectrum
* Neutral Inkset
* I am using the Full Spectrum Neutral inkset from MIS and the George
* Woolf curve on the MIS website. I have PiezoBW that contains the
* plugin but have not used it because of the inkset used with the
* George Woolf curve. That inkset can be used with the upcoming new
* upgrade of PiezoBW which uses ICC paper profiles. Well, today I
* decided on a whim to print an image with the plugin using the WRONG
* INKSET JUST TO SEE WHAT WAS DIFFERENT and the resulting print shows
* much more of the tonal range of the image than the curve designed for
* that particular inkset. If I am so pleased with these results, then
* how much better can the upgrade be than the plugin? The inkset
* mention is the FSN Hextone (Epson Driver used).
Johnny,
MIS designed the Full Spectrum inks specifically to work with the PiezoBW
plug-in. The Dmax will be a bit lower but in all other respects I would
expect you will get much better results. George DeWolfe's workflow was
designed for the Original QuadTone ink set which has different ink densities
than the Full Spectrum.
Martin Wesley
http://www.carolyn.cc/Guests/MartinWesley/pages/MW_01.html
http://www.borderless-photos.de/guests.html
