Re: [Digital BW] Clogging (was 1280 vs 2200 question)
2003-10-28 by A. Huntley
Hi Paul, In my experience with UT inks in my 1160 I actually had the most clogging issues with the grays cartridge. The Eboni black never seemed to be an issue. But, as you say I think it's a humidity issue and, maybe, related to the manufacturing disparities within each unit. Alan Huntley ----- Original Message ----- From: "Paul Roark" <paul.roark@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Monday, October 27, 2003 7:13 PM Subject: [Digital BW] Clogging (was 1280 vs 2200 question) > > >Is it possible to use the 1280, with the UT inks, on a regular but not > >high-volume basis, and not have these horror-stories about clogging? > > These inks do not necessarily clog. Perhaps its a humidity issue, but I > can't really say I've been able to see any specific pattern to the problems. > > Question -- Is the clogging mostly with the Eboni black? > > If so, would it be worth using Epson UltraChrome Matte black instead? If > that ink is purchased in 10K carts, it's not that expensive. If there is a
> market for such, I suspect MIS would do the re-packaging. > > Paul
