Re: 4000 vs. 7600
2003-10-31 by grdglass@aol.com
I saw the 4000 at PhotoPlus. Epson was not printing any B+Ws for distribution with it. When I questioned 3 Epson reps on the metamerism issue regarding the 4000, each seemed unaware that there was a metamerism issue with the Ultrachromes even on the 22/76/9600. None seemed aware of any new profiles or drivers for the 4000. I was able to get a B+W Rodney Smith print that was done on Epson Premium Luster, printed on the 4000. When I got home and looked at it under tungsten light, the print was totally neutral. Then I took it into daylight, and it was very green. Subjectively, I would say the 4000's metamerism is equal to that of the 2200 for B+W printing. I use my 2200 with ImagePrint. It's very disappointing because it now seems that the 4000, to be used with Ultrachromes, will require an expensive RIP for B+W. I wouldn't use it "as is" for B+W work. Helene > Here is an excerpt from the epson site that makes some subtle > distinction on the suitibility of these two printers for B &W > printing... > > 4000 > Professional Level Black &White Photographic Printing¹ > * Produces a truly consistent image with little color crossover or > colorcasts > * Reduced metamerism on 7-color black &white prints > * Depending upon media, produces a black D-max up to 2.1 > * Produces sellable quality neutral or toned black and white prints > > 7600 > Professional Level Black and White Photographic Printing > * Produces a truly consistent image with no color "crossover" or > color casts. > * Able to produce neutral or toned black and white prints to > satisfy demanding photographers. > * Depending upon the media used, you can produce a black D-max up > to 2.0. > > Draw your own conclusions.... I personally believe that these subtle > distinctions in Epson's product literature indicates a difference, > for some reason, in the B &W printing quality of these two printers. > [Non-text portions of this message have been removed]
