question about 6 Color Epson Printer Full Spectrum Workflow
2003-11-05 by radonprojects
Hi! New to working with MIS Hextone neutral inks. Been following the workflow and just have a question pertaining to this paragraph........ "This workflow is the same as my workflow for the 4 color Epson printers. Simply use the 6 color curve and printer settings. This curve will work best if you monitor is set to a gamma of 2.2. If it is calibrated to another gamma, you will have to adjust the curve mostly the toe. If you are not comfortable with editing curves, simply make a second curve or levels adjustment layer and use it to adjust print output to your monitor." does anyone know if its ok to just assign your profile for that file to gamma 2.2, or does the whole monitor actually have to be calibrated to 2.2? thanks! jen
