QTR Ultratone Dmax on PhotoRag ?
2003-11-12 by Ernst Dinkla
The QTR/Linux printing from commandline is a bit too primitive for me. For the moment I'm back to the Wasatch SoftRip for quad printing. I made new CMYK correction curves in the RIP and made the best of the 4 channel, very much colour printing (auto black generation etc) architecture of that RIP. At least it makes linearising with the Spectrocam possible. Though for the coolest curve I need the toner channel in non linear fashion. Then it is cooler than Paul's curve and cool into the black. The Eboni black in all the 4 curves is at least 1.85 on PhotoRag, checked it with a densitometer and Kodak's reflection guide as a reference. Is that a number that QTR users also get ? I have to add that at 60 % of the greyscale the ink quantity is then a bit too much, just before the black sets in. A detail greystrip with white lines through the steps shows some bleeding there. The neutral curve is showing it most. The dithering of the Wasatch isn't as good as Epson's or Gimp-print. After this exercise my esteem for Paul is even higher than it was. How on earth can you think in grey inks controlled by an RGB/CMYK colour driver like Epson with its hidden inklimits and black generation and do the steering by shifting RGB curves ? On the other hand I also think that the Ultratone VM set is very much compatible to that method and could have more suitable mixes for other methods like QTR or another RIP. The toner set for instance could be stronger with more blue pigment to keep the total ink quantity lower. If that is possible. I have printed some geometric art samples that have a more or less random distribution of 205 greys in squares. If the greyscale isn't linearised properly it shows in those samples right away. Could put a strip of that in the files section for others to use it. If the artist agrees. The best that could happen now to QTR on Linux is that the Gimp-print plugin of the Gimp functions with QTR. Even better would be a 16 bit dedicated Greyscale viewer with a similar driver menu and a display that shows the toned image based on the 0-100 % tone scale setting. Ernst
