Why back to RGB in B&W workflow?
2003-11-13 by alnchiem
Can someone explain to a relative novice, why it is , in many
worflows I've read, a grayscale file of a B&W image is converted back
into RGB before printing? How will the print differ if the grayscale
file is printed?
It's prob very obvious so no one ever explains it, so I've never seen
the explanation anyewhere.
Andrew
RE: [Digital BW] Why back to RGB in B&W workflow?
2003-11-13 by Paul D. DeRocco
> From: alnchiem [mailto:andrewlee@...]
> file is printed?
If you're printing an RGB image with color inks, you can impose a slight
overall tint to the B&W image.
2003-11-13 by Paul Roark
Andrew,
Are you asking about this in the context of a B&W/"quad" inkset or a color
inkset?
http://www.PaulRoark.com
_________________________________
Sent: Wednesday, November 12, 2003 9:28 PM
Subject: [Digital BW] Why back to RGB in B&W workflow?
file is printed?
Andrew
page.
them short.
resources on the homepage.
Re: Why back to RGB in B&W workflow?
2003-11-13 by B. Alex Pettit Jr.
I think what it is to which you are referring is the technique to
segment the various grey ink tones to grey shades of the print...
Consider the Epson driver: it creates grey shades by a balanced mixing
of cyan magenta and yellow inks to make grey. Thus the lighter shades
of a print above black will have small dots of CM&Y sprayed out on to
the paper. If the color inks are replaced with three shades of grey,
the Epson driver, if printing a B&W image, will do the same thing. The
result is that the darkest grey will be included in the very light
tones and visible dots will result.
Now a way to use only the light grey in the light areas, medium in
medium and the darkest grey ink in the shadows: If the lightest grey
is in the Yellow position, tell the Epson driver to print levels of
yellow ( 'color' ) and you will use Only the lightest ink for the
shades near white and render the print 'dotless'. Make areas of the
print a nice ugly magenta, and only the medium grey will be applied,
cyan colors in your RGB print (as shown on the monitor) will make the
dark greys.
So, your print must be converted to RGB, then turned in to intensely
colored areas to force the Epson driver to use an appropriate grey ink
for a particular grey level. If adjusted correctly, a segemented
workflow can create a wonderful dot free, fine quality black and white
print !
Best,
Alex
back
> file is printed?
> Thanks,
> Andrew
Re: [Digital BW] Why back to RGB in B&W workflow?
2003-11-14 by alnchiem
Well Paul, I don't recall if the workflows I've read specifically
relate to prepping an image for quad inks or not, but it seems common
for people to add this step of converting to RGB before sending to
print.
Andrew
<paul.roark@v...> wrote:
> Andrew,
a color
> inkset?
> Paul
Alex
thanks for that explanation. That ould mean much more work than just
converting from grayscale to RGB. Or is there some 'already
available' adjustment file to segment the greys in an RGB file so
that the Epson driver knows what to do? Is that the software in a QTR
or these adjustment curves?
Andrew
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "B. Alex Pettit
mixing
shades
to
The
> dark greys.
ink
white
> print !
> Best,
> Alex
2003-11-14 by Bill
You get a better (richer) blacks and a wider tonal range using all colors.  Of course if
your printer profile isn't good, you can also get a color cast.  I think that the best B&W
is printed with all colors (assuming not quad tones, etc), but also the hardest.  Some
will tell you that it can't be done, but they are wrong.
Bill
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "alnchiem"
> print.
> Andrew
> > Andrew,
> a color
> > inkset?
> > Paul
2003-11-14 by Herbert Sitz
> Alex
just
QTR
> Andrew
Andrew -- No real work, it's a simple process.  So long as your
printer is supported with pre-made curves, you just convert to RGB
and load the appropriate pre-made curve in an adjustment layer.  The
image will look funky on-screen but will print beautifully.
Paul R. and others have spent an incredible amount of time developing
curves for the most commonly used printers.
-- Herb
2003-11-14 by Stephen Kobrin
Is there a reason to load the Roark curves in an adjustment layer
rather than just applying them directly to the image?
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Herbert Sitz"
> > Alex
> just
> QTR
> > Andrew
The
developing
> -- Herb
