smoth transition of tones problem
2003-11-16 by frankg_photo
try what I may I cant get rid of the lack of smoothness between the tones in the cloudy sky section of a landscape shot. There's no point in posting a jpeg for you to see 'cos it looks good on screen even at 100% view but prints out like - i'm not even sure how to describe it - 'mottled' isn't exactly it but its close. This problem is most evident in the area where a darkish cloud texture meets the lighter sky texture. I did my scan and most of the initial corrections in 16bit and then some in 8. I'm working with Win98SE and PS7 and an 1160 printer with MIS sepia>neutral inkset on photorag. One symptom which may provide a clue for solving the problem, for someone, is that I had Layers for darkening/burning in the top of the image and the corners. The problem was excessive. Then I eliminated each of those layers (lighteninig the image segments) and the problem reduced or just became less evident I also have a High Pass sharpening layer - could that be it ? I just looked at Image>Histogram and find it pretty "comb" like - is this it ? Is it 'posterization' ? Should I go back to the 16 bit scan and try to do more there before converting to 8 and printing ? thanks Frank
