Anyone try the new piezo paper?
2003-11-20 by Jim Batzer
Has anyone used the new Piezography Museum Bright White paper with
UT inks? Any existing curves that work well with this paper? I'm
using a 1280 with UT inks. The paper sounds good and is cheap - 13 x
19 (25) for $46... Cheaper than Epson scrapbook paper.
I was also wondering if the 1280 can handle 300 gms paper. I know it
will handle .27mm thick paper (Epson site specs), but I don't know
how to convert the numbers (gms to mm to mil to lbs???). Also, at
what gms (or mil, mm, lbs.) should one start using the thicker
(envelope) lever setting?
Jim Batzer
RE: [Digital BW] Anyone try the new piezo paper?
2003-11-20 by Martin Wesley
* -----Original Message-----
* Sent: Wednesday, November 19, 2003 8:49 PM
* To: DigitalBlackandWhiteThePrint@yahoogroups.com
* Subject: [Digital BW] Anyone try the new piezo paper?
* Has anyone used the new Piezography Museum Bright White paper with
* UT inks? Any existing curves that work well with this paper? I'm
* using a 1280 with UT inks. The paper sounds good and is cheap - 13 x
* 19 (25) for $46... Cheaper than Epson scrapbook paper.
Jim,
Can't help you the new paper but....
* I was also wondering if the 1280 can handle 300 gms paper. I know it
* will handle .27mm thick paper (Epson site specs), but I don't know
* how to convert the numbers (gms to mm to mil to lbs???). Also, at
* what gms (or mil, mm, lbs.) should one start using the thicker
* (envelope) lever setting?
I have run many, many sheets of Photo Rag 308 gsm and German Etching 310 gsm
through my 1280's without a problem. I have never adjusted the paper
thickness lever from the minimum setting. The thicker papers will probably
need a gentle push to get started and/or a foam core support piece in the
paper feed tray.
You cannot convert gsm (grams per square meter) to thickness. The density of
the paper does not directly relate to how thick it is. The stiffness of the
papers varies a lot too and that effects paper handling. As far as I know
the 1280 should handle any paper in the 300 to 350 gsm range. I have not
tried anything beyond that.
If you do try the new paper please let us know what you think.
Martin Wesley
http://www.carolyn.cc/Guests/MartinWesley/pages/MW_01.html
http://www.borderless-photos.de/guests.html
Re: Anyone try the new piezo paper?
2003-11-20 by digikdm
Yes, I've tried the new Museum White Piezo paper. I don't use piezo
inks however. I use ImagePrint software on an Epson 2200. I used the
profile for epson velvet fine art and got a beautiful B&W print. Have
not printed color yet.Assuming
this paper is as archival as velvet fine art paper( that might be a
big assumption), it is the best paper I've come across. It is thick
and very white( as white as epson enhanced matte). Blacks are as deep
as on any epson paper by visual inspection. My only problem is that I
have no specific paper profile for the ultrachrome inks using
imageprint sofware.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jim Batzer"
x
it
> Thanks,
> Jim Batzer
Re: [Digital BW] Re: Anyone try the new piezo paper?
2003-11-20 by Carl Schofield
I've profiled this paper for the 2200 with UC inks using QTR.  Dmax was
only 1.58.
Carl Schofield
> imageprint sofware.
> x
> it
>> Thanks,
>> Jim Batzer
> Buy Ink Cartridges or Refill Kits for your HP, Epson, Canon or Lexmark
> Printer at MyInks.com. Free s/h on orders $50 or more to the US &
> Canada.
> http://www.c1tracking.com/l.asp?cid=5511
> http://us.click.yahoo.com/mOAaAA/3exGAA/qnsNAA/ucIolB/TM
> Please visit the Group Homepage to check the Files, Bookmarks, Polls
> and other resources as they are often being updated. The page is at:
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> - As the topic of a thread changes remember to change the subject
> header.
> - Good manners are required at all time. No personal attacks or flames
> - Before posting a question, search the message archives and the
> various resources on the homepage.
> Your use of Yahoo! Groups is subject to
2003-11-20 by Alan.Huntley@cox.net
If you have a maintenance agreement (or know someone who does), ColorByte will generate profiles upon request. This benefits all IP users because they will be posted on their FTP site for all to use.
Alan Huntley
> From: "digikdm" <monroekd@...>
> Date: 2003/11/20 Thu AM 11:58:24 EST
> Subject: [Digital BW] Re: Anyone try the new piezo paper?
> imageprint sofware.
2003-11-20 by sceptre12345
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield
was
> only 1.58.
> Carl Schofield
Here's what John Custodio reported on the Piezo list about this paper
and the PremierArt Hot Press:
Message #23390
"Yes, I tested Piezography Museum Bright White with
Studio Print and got a Dmax of 1.65 with PiezoTone
Selenium and Portfolio Black. Not as good as
Hahnemuehle Photo Rag (1.74) but better than the
Ultrasmooths."
-John
Message #23345:
"I tested Premier Art and Epson Ultrasmooth with
PiezoTone Selenium and Portfolio Black using Studio
Print and got a meager 1.55 Dmax on both papers."
-John
Andre
2003-11-20 by Anders Jonsson
Hi there,
Have anyone of you tried the "Condor Bright White" 290gsm dual sided from Hawk Mountain Art papers? go to www.hawkmtnartpapers.com and request samples. I think you will like it.
Anders
was
> only 1.58.
> Carl Schofield
Message #23390
Ultrasmooths."
-John
Message #23345:
-John
Andre
Do you Yahoo!?
Free Pop-Up Blocker - Get it now
