Hp 7960 or 1290 with MIS-inks?
2003-12-03 by flabes23
Hi!
Since my Epson 1290 has microbanding-issues with the MIS VM-inks that
I can't get rid of, I´m seriously thinking about buying the new HP
7960. And opinions of which model is better (7960 versus 1290 with
MIS-inks)?
Peter
Re: Hp 7960 or 1290 with MIS-inks? - Try these steps
2003-12-03 by scrber
Hi Peter.  I am not aware of which steps you have gone through to
solve your microbanding issues, but I also use UT (and used VM before
that) in a couple of 1290's which had, and often still do have
microbanding issues.  BUT it can be removed, and although it takes a
bit of effort, the results when the printers are printing cleanly are
fantastic.  To give you an idea, I printed 110 double sided A3+
prints, using almost a full set of 110ml bottles and only at the end
was I starting to see microbanding again.
If it helps, here are the common causes and steps that I have
found/used :
1. Seems to be paper dependant.  I hardly ever (in fact don't think I
ever have) see banding on Photorag, this is because the ink seems to
spread a little more and hide it.  With much smoother papers such as
Imajet Satin and Red River polar/premium there is minimal spread to
the dots (this can be seen through a loupe if you're interested) and
banding is more prevalent.  EAM is somewhere in the middle.
2. Clean the heads!  and I don't mean the Utility option.  I always
got clean nozzles, but still saw banding, on some occasions quite
heavy.  The answer is to use a folded up piece of lint free kitchen
roll sprayed with Windowlean or another glass cleaner (not until it
is soaked, just damp) - I actually use half a flash kitchen wipe.
Fold it up until it is around 12mm wide, just enough to fit under the
head in the small slot.  I often wrap a small piece of Sellotape
around the ends so that the head doesn't get stuck as it goes over.
Lift the head to the + position and with the printer off, release the
park by turning the large toothed wheel on the LHS a small amount.
Run the head gently over the paper by hand and lower it to 0.  Leave
for a few second and then gently move it back to the park position.
This cleans off the gunk that forms on the underside, which deflects
the nozzles away from their intended path.  You know this is a
problem when you see banding in your alignment patterns.
3. Move the head back to it's correct height position (I only use +
for papers over 200gm, for EAM for example it is always in the 0
position) Align the print heads with the utility software.  Use the
correct paper to do this and if possible use a loupe and a lighbox to
check the results.  If necessary do it twice, I know it takes time
but it does make a difference.
4. On occasions it is only one colour that causes the problems.
Print a 6 colour purge pattern (ie Cyan, light cyan, etc etc. - you
can get these from the MIS site) and check whether the banding is
still there.  If it is and in all colours, repeat steps above.  If it
is only in one colour - and I see this most of the times I get a
problem - raise that one bottle about half an inch (unless your using
carts, in which case you may need to change them and repeat above
steps again...) to increase the line pressure a little and print a
few more purge pages.
5. Finally, after all of the above, try printing with and without
high speed.  On the 1290, with aligned print heads the difference is
minor, only really discernable through a loupe.  BUT that tiny
difference sharpness which is caused by bi-directional printing can
give big advantages for banding as they can mask each other on the
two strokes.
I hope this helps.  Long winded, and I may be `teaching my
grandmother to suck eggs' in which case I apologise.  The 1290 is a
super workhorse.  The VM/UT solution very efficient and cost
effective – don't give up on it just yet.
Let me know how you get on.
Kind regards
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "flabes23"
<peter.bongard@t...> wrote:
> Hi!
that
> MIS-inks)?
> Regards
> Peter
Hi Steve,
thanks for your detailed post, but unfortunately I did everything you
suggested. I will give you a more detailed report on what I`ve done
yet.
Some weeks ago I moved to a new flat. During the drive to the new
house I tried to leave the ink-bottles and the printer on the same
heigh. Some days later. I printed fifty thick cards. I therefore
changed the lever from 0 to + position (it's in the + position since
then, because I mainly print on Tetenal or Permajet 240g Archival
Matte). During that time I often got bad nozzlechecks and after one
photo-print was suddenly missing the grey color, I decided to flush
the cards using the syringe-method the MIS-guys suggested on their
site (I did everything exactly as they described except the step
where a brand new cardrige set is needed in order to check if the
print head works fine...sorry ;-), but apart from the bad nozzle
checks I got from time to time the prints were perfect-no banding
whatsoever! So the printheads were ok until that point). After that
the trouble began: I got very fine horizontal lines on my prints
(microbanding, I guess), although I always had a perfect nozzle-
check. It seemed as if less ink came onto the paper than before the
card-flush. The whole image didn't look as "rich" as it looked
before. After that I tried some methods I learned from various
forums: Printing out the purge-file. No improvement. Run various
cleaning-cycles. Still no improvement. Then I tried realigning the
printheads several times along with the Windex-trick and the raising
of the bottles. After that the picture looked better, significantly
better, but the banding is still there. Since I'm a photographer,
this situation is very vexing for me. Now I'm going to sacrifice one
more sheet of my beloved Tetenal Archival Matte and do a proper
Windex-treatment before that. Then I realign the heads once more, but
if this doesn't work, then say goodbye to Mr. Epson :-< . So Steve,
after hearing my whole story - do you have any idea what could cause
this problem or if there is any other thing I should test? My
suspicion is that I made something wrong during the card-flush. Maybe
I should repeat it, now with the cardrige-step included? Apart from
that, do you think that the hp 7960 can print out b/w as beautiful as
my Epson with the MIS-inks?
Thanks for your advice. I'm actually quite desperated.
Peter
Re: 1290 with MIS-inks, microbanding ? - Try these steps - ONE more
2003-12-04 by scrber
OK, so you have at least improved it.  Thats a start.
There is one more thing that could be affecting the printing.  That
is that the paper is not being 'indexed' forward enough at each step.
There are two causes.  One common, I get it a lot with my printers
after heavy use, the other pretty rare, I have read about it but
never seen it.
1. Your paper has a coating, normally a kind of chalky substrate that
accepts the ink.  This coating is extremely slippy and over a period
of time can build up on the rollers that feed the paper and cause a
tiny amount of slip each time the rollers try to 'grab' the paper in
order to move it forwards.  When I use my satin matt papers such as
imajet, there is a huge amount of coating deposited on the rollers.
After 50 or so prints, the grab roller wont even feed the paper
anymore.
So, what do you do?  Two steps.
i. Take normal plain bond paper, 50 sheets of and feed them through
the printer.  Just stick a fullstop on a blank page in word and let
it go.  This clears a lot off.
ii. Next step is to spray some more of our beloved windex onto some
more bond paper, especially on the RHS where it is grabbed. NOT too
much because it will tear up, but enough that it is damp.  Feed wet
sheet after dry sheet alternately about 10 sheets.
iii.  Finally if you feel around inside the paper feed tray you can
find two thin plastic flaps that cover the 'grab' rollers.  Gently
fold these back outwards and that a cotton bud soaked with Windex.
Rub the grab roller with the cotton bud and see how much gunk comes
off.  Normally it helps to get the printer into a red light 'no
paper' situation so that you can press the feed but to cycle it a few
times, this gives you access to more of the roller and can clean it
better.
iv. Use a number of sheets in your printer paper tray, it places the
top printable sheet closer to the rollers and helps it to feed.  If
you check the posts prior to this someone found that this step alone
cured their problem.
Now the second possibility....
2.  Your band that drives the paper feed has stretched.  This could
theoretically mean that you will always get banding - even in your
alignment patterns.  As I said before, I have never known this
happed, only read about it during my lengthy research to solve the
same issues you have.
Also, try changing papers.
Take a cheap EAM and see how that improves this on the 0 setting.
I have no experience with the HPs, but you can just look around this
board and see that most people swear by their Epsons and have found
ways to solve most of the issues.  At the end of the day, we are
tinkering with things that weren't really meant to be....There is no
telling what problems you may have with an HP.  Some of the issues
above could be just the same.
Good luck
Steve
> Hi Steve,
you
> yet.
since
raising
one
but
cause
Maybe
as
> Regards,
> Peter
2003-12-04 by flabes23
Hi Steve!
Thanks again for your detailled post. I'd love to say that there had
been an improvement but nothing changed after performing all of your
steps. Now- before I dump my 1290 (which I'd hate to, because before
the banding issue it produced beatiful prints) and get the 7960,
there are two more questions I have:
1) when trying to align the prints, I never get a grain-free box in
the second column. The row that is printed first shows an ok box at
around "5" (but the banding is also visible there), but even after re-
adjustement there isn't a grain-free box in the second row (I can see
no improvement in both rows when clicking re-adjust (sorry, don't
know how this button is called in the english epson-software)). Could
this have something to do with my issue?
2) What about a software problem? I have a usb-hub. Could the signal
from the PC to the printer be "bad", so that it produces microbanding?
Thanks again!
Peter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "scrber"
step.
> never seen it.
that
period
in
rollers.
> anymore.
few
> better.
alone
this
no
> Good luck
> Steve
> > Hi Steve,
> you
done
> > yet.
same
> since
one
flush
their
that
> raising
significantly
> one
> but
Steve,
> cause
> Maybe
from
beautiful
> as
> > Regards,
> > Peter
2003-12-05 by Bob Michaels
Peter: banding can be caused by either clogged nozzles or ink feed
problems. Ink feed problems are frequenty the cause with a CIS or CFS.
That's why MIS suggests you put new Epson carts in to see if that
solves the problem. If so, it's a feed problem and nothing dealing
with clogged heads will help. Follow the MIS advice and try Epson
carts. That may just diagnose the problem as ink feed.
I had banding and bad nozzle checks after changing carts and inks in
my 1280 with a MIS CFS. But I knew it was a feed problem since it went
away with Epson carts. Sucking ink from the CFS bottle via bottom fill
didn't help as it usually did. But disconnecting from the CFS tube,
then emptying and then refilling the Eboni cart via bottom fill solved
the problem.
My MIS CFS has been 99% reliable but there's still some "black magic"
involved in the way they work.
Bob Michaels
> Hi Steve!
> Thanks again!
> Peter
> step.
> > never seen it.
> that
> period
> in
> rollers.
> > anymore.
> few
> > better.
> the
> alone
> this
> no
> > Good luck
> > Steve
> > > Hi Steve,
> > you
> done
> > > yet.
> same
> > since
> one
> flush
> their
> that
> the
> the
> > raising
> significantly
> > one
> > but
> Steve,
> > cause
> > Maybe
> from
> beautiful
> > as
> > > Regards,
> > > Peter
2003-12-05 by flabes23
Bob, can you give me a detailled description of the bottom-fill
procedure?
Peter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Michaels"
CFS.
went
fill
solved
> the problem.
magic"
> Bob Michaels
> > Hi Steve!
had
your
before
in
at
after re-
see
Could
signal
microbanding?
> > Thanks again!
> > Peter
That
> > step.
printers
but
> > > never seen it.
substrate
> > that
> > period
cause a
paper
> > in
such as
> > rollers.
> > > anymore.
through
let
some
too
wet
can
Gently
Windex.
comes
a
> > few
clean it
> > > better.
places
> > the
feed.  If
> > alone
could
your
setting.
> > this
found
are
is
> > no
issues
> > > Good luck
> > > Steve
> > > > Hi Steve,
everything
> > > you
I`ve
> > done
> > > > yet.
new
> > same
therefore
position
> > > since
Archival
after
> > one
> > flush
> > their
step
nozzle
banding
After
> > that
prints
nozzle-
before
> > the
looked
various
various
realigning
> > the
> > > raising
> > significantly
photographer,
sacrifice
> > > one
proper
more,
> > > but
> > Steve,
could
> > > cause
flush.
> > > Maybe
Apart
> > from
> > beautiful
> > > as
> > > > Regards,
> > > > Peter
http://www.inksupply.com/index.cfm?source=html/virgin110.html
from the support section of the MIS site explains the bottom fill
method much better than I ever could.
Not on the site, Bob Zeiss told me to suck out the Eboni then refill
with 10cc of ink, thus leaving a bit of air in the CFS cart. That
solved my problem.
Between info in the support section and the CFS section on the MIS
site, there is a wealth of information there.
Remember to diagnose you banding problem as clogged nozzles or a CFS
feed problem by trying Epson carts first.
Bob Michaels
> procedure?
> Thanks,
> Peter
> CFS.
> went
> fill
> solved
> > the problem.
> magic"
> > Bob Michaels
