Oriental FB Glossy with MIS VM and VM-S in BO mode.. SUCCESS!
2003-12-04 by Editor P.O.V. Image Service
It was quite easy.. All I needed to do using Clayton's Method was limit the grey output via curves to 97% for 100% input.. No more bronzing and I keep the deep blacks... Given the small amount of ruboff, I'd recommend spraying with a fixative after curing.. Print looks GREAT though, I REALLY like the look of this paper with BO (Clayton, you've got me eating my earlier words of disdain for the BO workflow).. It does look VERY much like a ferrotyped B&W Fiber print.. (let's hope I can find a fixative that doesn't alter that - anyone have a suggestion of one?) However, the sepia toned inks are another issue entirely... Will try and tweak curves that lower it enough to allow a more Roark-like workflow that uses more of the tonal/color capabilities of this and the VM set.. Of course, this may all be mooted for me once I start using the UT v2 inkset, but that's another issue.. Some may still find themselves using the VM sets, and this hopefully gives them a viable glossy option.. I'll email the curve and instructions to Martin Wesley for posting in the files section.. I'll also send a copy to Oriental and MIS, in case they want to post it.. -- Keith Krebs "Just some guy," and caretaker of the Multiverse's largest EPSON printer User Community (highly recommended by Vogon Poets and MegaDodo Publications), at: http://groups.yahoo.com/group/EPSON_Printers/ "For the rest of you out there, the secret is to bang the rocks together guys" [Non-text portions of this message have been removed]
