1160 Intermittent Banding
2003-12-05 by rbehr2001
Having a problem with intermittent banding on my 1160. The printer has a nomorecarts CFS and MIS VM ink. On three identical 13x19 prints made at the same time one print is fine, one shows light banding across the entire print, and a third has severe banding across half of the print and the other half is fine. The problem then disappeared for a while. In the last few days I've been making a lot of grayscale tests to do some calibration. Yesterday I made a small test print in the morning that had significant banding but only above 50% Grey. The gray patches were arranged on the sheet such that the banding should have crossed all shades of gray but the banding was only at 50% and above, seeming to make dark gray the culprit. The same print made this morning is fine. Is this normal banding? The only previous banding experience I've had it was there all the time. Bob
