QTR and 7500 with UT
2003-12-16 by jharvey@isd.net
Please let me know if anyone is using QTR with UT Inks on Mohab or Photo Rag with a 7500. I'd appreciate it if you could attach a copy of your curves so that I may check mine against yours. I also wonder if anyone has tried both the 7500 drivers and the 7000 drivers on a 7500 to see if there is any advantage of one over the other. I know there were some problems with Epson 7500 drivers using the VM inks so that some chose to switch to the 7000 drivers. I'm still having trouble getting a really smooth curve using only the 3 gray inks and the black. Is it possible to Linearize and then take that Linearized curve and relinearize it to make it smoother? John H
