Print Shield tests on semi-gloss
2003-12-20 by Carl Schofield
I made three test prints (each consisting of a 21 step wedge and a panel of 4 small images with varying tonal range) on Epson Premium Semi-gloss (Epson 2200 printer) for evaluation of the PremierArt Print Shield spray. BO prints were made with the Epson driver at 2880 dpi and a 20% dot gain print profile. QTR prints were at 1440x720 dpi Highest Quality from graycale mode in gamma 2.2 workspace. The procedure was to spray prints with overlapping strokes going left to right across the long axis of the paper from top to bottom and then immediately rotate the paper 90 degrees and repeat spraying. Waited 10 minutes and then repeated the spraying procedure for a total of 4 coats. I also repeated this a 3rd time the following day on the QTR print to see if there was any further reduction in bronzing. Here are the results: BO print made with MIS Eboni: Dmax 3 hours after spraying: 2.13 No bronzing Very slight gloss differential visible in shadow areas Visible "grain" in midtones (approx. 45-70% area of step wedge) Highlight dots not visible to me without using a loupe Overall print hue - neutral BO print made with Epson UC-PK: Dmax 3 hours after spraying: 2.41 No bronzing No gloss differential Slight "grain" in midtones, not as noticeable as in the Eboni print Highlight dots not visible to me without using a loupe Overall print hue - very warm QTR print made with a "neutral" profile using Epson PK, LK, LC, and LM inks Dmax 3 hours after spraying: 2.44 (2.47 after 3rd spraying the following day - total of 6 coatings) Bronzing still visible, but significantly less than before spraying. Tolerance levels for this residual bronzing will vary and also depends on lighting. No gloss differential after spraying No midtone "grain" Highlight dots not visible to me without using a loupe Overall print hue - neutral/warm (shadow areas warm). I have great difficulty controlling the warmth of the PK and LK inks with the LC and LM inks on semi-gloss. The LK, LC, and LM inks also exacerbate mid-tone bronzing (there is none with just PK). These are probably not the best inks for B&W printing on RC papers. I think that a UT-2 inkset for the 2200 with stronger toners and/or more neutral gray/black inks would help. Although I didn't test the UT inks in this trial, previous experience indicates that it is also difficult to control bronzing and warmth of the current UT inkset for the 2200 on RC papers. Note also that the spray treatments affect base density and linearity of the profiles, so probably best to linearize profiles after spraying and drying (assuming spray procedures are standardized). I really like the smooth surface of the semi-gloss sprayed with Print Shield - as Paul noted it is very close to the luster of an air dried silver print. I currently prefer the appearance and hue of the BO prints for busy landscapes or images without large, smooth mid-tone areas.
