Re: [Digital BW] Digest Number 1986
2003-12-21 by Jack McLain
Saturday, December 20, 2003, 3:11:43 PM, you wrote:
s> I have the Nikon Coolscan IV version 3.1.2 (driver)
s> I'm using a PC with Windows XP.
s> Digital ICE is turned OFF.
s> My problem is when scanning black & white negatives the scans come
s> out with a dark band (as much as a 1cm width when viewing the
s> preview images) that spills from the outer edge onto both short ends
s> of the frame, as if too much light was reaching that part of the
s> frame or something.
s> I am choosing Monochrome Neg and Grayscale when scanning.  The dark
s> bands appear in the small          s, previews, and actual scans.
s> As I crop when I shoot, the edges of my images are very important to
s> me.  I cannot afford to crop out this darkened edge.
s> This problem does not happen with slides or color negative film.
s> Can anyone help?
I use the same gear and have exactly the same problem.  It seems to be
mechanical, in that the negs are not "centered" in the scanning field.  It
is extremely annoying.
I eject the negative strip, and reinsert, sometimes inserting the other end
of the strip.  What is baffling is that it is not a consistent problem
either in when it happens, or to the degree of how much of the scan is
effected.
I assumed that my unit might be a lemon or just plain "broken" (I bought it
sight unseen on-line "used").  Hearing that another user has the same
problem I am somewhat reassured that this is a problem with our technique or
inherent flaw in design.
I'd be interested in any off-line responses you might receive.
best of luck
Jack McLain
Tucson, AZ
http://jackmclain-photography.dotcommunity.net
