OT Ink Question
OT Ink Question
2003-12-21 by bfwoolner
Can MIS UT ink prefilled carts be used with OEM inks on Epson C82???  or do
I have to remove all OEM inks before installing the UT ??
Thanks for any response.
Barbara Woolner
RE: [Digital BW] OT Ink Question
2003-12-21 by Paul Roark
Barbara,
I'm not sure I understand the question.
The only UT-family inks for the C82 are the "Easy B&W" carts.  So, I assume
that is what we are talking about.
As best I can tell they are compatible with the OEM Durabrite inks, which
are pigmented.  I have interchanged carts with no ill affects.  I've tried
the 2 blacks and think that the MIS Eboni is better.  I'm not sure if I've
tried a Durabrite color image with the Eboni, but it might work well on
matte paper.
Let us know how mixing works if you give it a try.
Re: [Digital BW] OT Ink Question
Sorry for the asking the wrong question altogether.  You did answer it,
however.  I meant the Durabrite inks.  Thanks, Paul.
Barbara
