First impressions - Piezo ICC on 1280
2003-12-29 by sanfo2003
Finally got the new Piezo ICC system for my 1280. Installed easily
(Windows) without a glitch and up and running with first print in 20
minutes. Used Piezotone Museum Black with Selenium tone inks. Results
are excellent. Besides excellent quality its a breeze to use with
familiar settings in Photoshop and the Epson driver. The ability to
have a dead-on soft proof is super and will no doubt save ink and
paper. My color managed setup had the screen almost exactly (as much
as transmitted light vs. reflected light will allow) matching the
print. Dithering is better than the Piezo plug-in, buttery smooth
with less microbanding and solarizing; in other words, its more
forgiving of Photoshop levels and curves adjustments. I did tweak up
my sharpen settings just a bit with the ICC system vs. the plug-in.
The ICC system prints about twice as fast as the plug-in and doesn't
tie up Photoshop so now you can work on another image while printing.
I have an image I use as my torture test of printer resolution. Its a
photo taken with a Canon D1s and contains in the photo an image of a
screened window in front of a white background. At first I thought
the window was tinted until I printed on the Piezo plug-in when to my
amazement I saw a criss-cross pattern of a screen mesh. I bumped up
the magnification on my monitor to 50% and yep, there was a screen
over the window and the window was not tinted. Needless to say I was
impressed with the resolution of the plug-in. The question was how
would the ICC system handle this image using the Epson driver at
1440dpi. I'm pleased to say that the screen mesh was still clearly
visible with the ICC system and almost identical to the plug-in (the
plug-in may be just a tad sharper). Now this isn't a scientific test
done with sophisticated test patterns, but resolution is certainly
more than adequate.
The appeal of this system to me is no trial and error, no curves,
WYSIWYG, and great inks. A couple of pointers: be sure to carefully
follow the setup instructions and be especially careful on when in
the flow to check on or off black pt. compensation (in Photoshop). I
was warned of this in the Piezography3000 forum. Following the
instrucions closely gave me a problem free positive experience with
this fine product. Now, if Inkjet Mall would just not have to
backorder so much ...
