Computer Mechanics - upgrading RAM with XP?
2004-01-02 by Lyons Cox
I'm one of the many who, to upgrade to Photoshop CS, will have to upgrade
the OS to XP.
Since the 512 RAM was a limitation of Win98, I was wondering if people were
upgrading their RAM at the same time?
I've stuck other equipment into the box but haven't done a RAM upgrade yet
and was wondering if its a simple?
I'd like to go from 512 to 1G.  Suggestions?
Cleavis
Re: Computer Mechanics - upgrading RAM with XP?
2004-01-02 by Bob Michaels
with XP: turn off machine, insert RAM, turn on machine. It doesn't get
much simpler.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Lyons Cox"
upgrade
> the OS to XP.
people were
upgrade yet
> Thanks,
> Cleavis
Re: [Digital BW] Computer Mechanics - upgrading RAM with XP?
2004-01-02 by Robert Zwemer
Should not be a problem. Depends on your system. Most conventional
motherboards allow 3 dimm slots. depending on what your current
configuration is will determine if you can save your current memory.
There are a number of places which sell memory, do a google or froogle.
Here is one I have used and reccomended and not heard anything but
positive comments. You can enter your pc model etc. it returns info. on
the type and size of memory available. http://www.memorysuppliers.com/
Bob
>the OS to XP.
>Thanks,
>Cleavis
>Please visit the Group Homepage to check the Files, and other resources as they are often being updated.
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
>Please follow these basic guidelines:
>- As threads develop, trim off excess portions of earlier messages to keep them short.
>- Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice.
>- Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership.
>- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
>BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
>Yahoo! Groups Links
>To visit your group on the web, go to:
>To unsubscribe from this group, send an email to:
> DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
>Your use of Yahoo! Groups is subject to:
2004-01-02 by johnglodge
It may or may not be simple. Depenent on the age of your system.
The older ones can only support 256M RAM If you have one of those
the RAM cards are quite specific and you likely have only 3 slots so
you will get to 768M. Otherwise 512M cards are possible or the less
expensive 256M cards that can alos be used.
When changing memory it is quite likely that you will get a bad
contact first time around. Look at your motherboard manual and see
what memory combinations you can support. I would suggest not
changing everything at once. Put one new RAM in (not in the first
slot) see what happens if it is recognised properly promote it to
the first slot and then put in the others step by step.
There is nothing like flying completely blind by changing every
thing and facing a machine that only manages to beep a warning but
will not boot.
At every memory change some machines insist on going through the
CMOS setup even though they recognise the memory change.
You also need to figger how to turn your machine off. The on/off you
are accustomed to is really a soft on/off there may be another on
the back of the machine or just pull the plug out of the wall.
For many machines if you fiddle with expansion slots or memory slots
while the machine is only soft off you will kill the motherboard and
an unspecified number of what is connected to it.
In summary it is a very simple job to change memory but the margin
for error can be non-existent.
upgrade
> the OS to XP.
people were
upgrade yet
> Thanks,
> Cleavis
2004-01-02 by Steven Karafyllakis
upgrade
> the OS to XP.
Nothing complicated about it, buy the right kind and stick it in. My
research indicates that it is more efficient to have a single large
chip than several small ones, so buy it in one chip if your MOBO
will support it. Also, while you're at it, if you can afford to, buy
more. I've had CS only a few days and I'm already going to 2G of ram
from one. It seems editing in 16-bit raises the overhead a lot!
Steve Karafyllakis
2004-01-02 by Editor P.O.V. Image Service
Paul D. DeRocco wrote:
>>From: Lyons Cox [mailto:lyonscox@...]
>>the OS to XP.
>>people were
YES..
>Since when did Win98 have a 512M RAM limitation?
Since it plopped onto the scene:
<http://www.buycomputermemory.com/faq.html>
Workarounds are available.. They didn't work for me, but an M$ Knowledge
Base article on those is at:
<http://support.microsoft.com/default.aspx?scid=http://support.microsoft.com:80/support/kb/articles/Q253/9/12.asp&NoWebContent=1>
Keith Krebs
"Just some guy," caretaker of the Multiverse's largest EPSON printer
User Community (highly recommended by Vogon Poets and MegaDodo
Publications), at:
http://groups.yahoo.com/group/EPSON_Printers/
and  the Multiverse's largest Canon printer User  Community at:
http://groups.yahoo.com/group/Canon-printers
"For the rest of you out there, the secret is to bang the rocks together
guys"
RE: [Digital BW] Computer Mechanics - upgrading RAM with XP?
2004-01-02 by Paul D. DeRocco
> the OS to XP.
> people were
Your mobo may have a limitation, however. Check the manual, or go to the
support area of the mobo manufacturer's web site if you can't find it.
The physical act of adding RAM is generally easy, although after pushing
ribbon cables around to get at the RAM sockets, make sure their connectors
haven't come unseated.
2004-01-03 by Anthony G. Atkielski
Lyons Cox writes:
> Since the 512 RAM was a limitation of Win98 ...
I don't recall Win98 being limited to 512 MB, although it handled large
amounts of RAM quite poorly.
> ... I was wondering if people were upgrading their
You can never have too much RAM, and modern bloatware requires more and
more of it to accomplish the same things.
Usually it's just a matter of opening the box and plugging in some new
memory (with the computer off).  Then you turn things back on and you're
in business.
Buy some memory and plug it in.  Look at the memory you have installed,
first, though.  To get to the maximum on a machine, you'll have to
install the largest memory modules you can, and if smaller modules were
installed at the factory, you'll have to unplug those and plug in new
ones to reach the configuration limit.
In any case, many PCs won't handle more than 1.5 GB from a hardware
standpoint, and Windows XP can't go past 2 GB, I think.  The 32-bit
architecture for the hardware can't directly support more than 4 GB.
All of this is more than enough for most purposes, but when you edit
images, you can never have enough RAM.  I have the maximum of 1.5 GB
installed on my machine, and it is still just barely enough to load MF
scans.  If I went to a higher resolution scanner or a larger film
format, I'd be unable to process scans at all, since neither the OS nor
the hardware will configure enough memory to do it.
