Epson 2200 Gray Balancer Software Actually Helped !
2004-01-08 by Tony Bonanno
Hi All, Like many others, I spent a lot of time trying to get decent B&W output from my 2200 without serious metamerism and almost had given up. Looked like ImagePrint was the only answer, but then I would have had to sell my car :-). Then I discovered this group and started using the Black Only output (which is pretty good if you don't mind the dots and don't desire any toning). While reading the archives, I noticed a couple of posts that referenced the Epson Gray Balancer software that shipped with the 2100, but not the USA 2200. Most folks indicated that it was a waste of time. I had almost forgotten that I had a copy of the Gray Balancer software, so I started messing with it (as a last resort). After a zillion hours of experimenting and a couple of trashcans full of Epson Enhanced Matte proofs, I can tell you that, for whatever reason (perhaps a lot of luck), I'm getting pretty darn good results using EEM paper, the standard 2200 enhanced matte/MK profiles, standard UC inks, and my newly configured Gray Balancer settings! I'm seeing output with barely any hint of metamerism. I'm actually VERY pleased. I'm a full time working photographer and my interest in B&W was mostly for my personal work. Interesting enough, since inserting the Gray Balancer into my workflow, the color accuracy of my commercial COLOR prints is detectably better. The bottom line of all this, at least in my case, is that the Gray Balancer software has brought new life to my 2200 and my workflow. By the way, in case anyone is interested, I put most of my effort in establishing a "neutral" tone by selecting values on the "4-point Gray Adjustment" based on "daylight" visual comparisons. I wound up with values of 361, 251, 151, and 051, for my specific printer. I doubt that these values would be applicable to other 2200's, but who knows, might be worth a try if you've got the software sitting in a folder somewhere on your computer. Tony Bonanno
