2200 and MIS UT inks
2004-01-10 by dave08g
I am presently printing B/W images on Mac OS9.2, Open Printmaker,
Epson 2200 and Epson UC inks.
Are there any advantages to converting to MIS Ultratone inks?  From
bits and pieces that I've read, both UC (matt and light black) and (UT
black and gray inks) are carbon so the longevity should be similar.
And the MIS UT color pigment inks used for tinting are supposedly
similar to the UC color inks.
One potential advantage of MIS UT could be smoother tones resulting
from using 4 inks (1 black and 3 grays) instead of 2 inks (matte black
and light black) used with UC and OPM.
The last time I checked the MIS website, it says you need either OPM
(OS9) or QTR (OSX) to use the UT inks on a 2200.
Has anyone out there used both the OEM UC inks and the MIS UT inks on
a 2200?  And if so, is it worth converting to the UT inks?  What are
the advantages?  And if conversion to UT is worthwhile, are there any
IJC/OPM (or QTR) profiles (for 2200) available for UT on various
papers?
Dave Gordon
http://www.davegordonpho
Re: [Digital BW] 2200 and MIS UT inks
2004-01-10 by Carl Schofield
Dave,
I made some UT profiles for QTR (beta8) that are in an archive on my
filesharing site.  There are also some "hybrid" profiles that use the
UC inks and just the UT Y and M ink positions.  The tones are a bit
smoother with the UT inks, but visually I have difficulty seeing any
dramatic differences except in high key images with smooth tonal
gradients.  I think that MIS or Bowhaus may have a few OPM profiles for
the UT inks, but I don't know if they will release them.  If you decide
to go with the UT inks (or a subset) with QTR you will need to be
running OS X.  The QTR beta8 profiles would probably also need some
slight modifications and re-linearization to run under the latest QTR
beta9 release.
Carl
http://homepage.mac.com/scho/FileSharing2.html
> papers?
> Thanks,
> Dave Gordon
Re: 2200 and MIS UT inks
Carl,
Thanks for your advice.  I think for the time being I'll stick with
IJC/OPM and UC inks.  There doesn't seem to be a huge advantage to
making a switch to UT right now.  Perhaps I'll experiment with UT and
QTR when I upgrade to OSX.
Dave Gordon
davegordonphotography.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield
<scho@m...> wrote:
> Dave,
for
decide
QTR
> beta9 release.
> Carl
From
(UT
similar.
resulting
black
OPM
on
are
any
> > papers?
> > Thanks,
> > Dave Gordon
> > http://
Re: 2200 and MIS UT inks/OPM
2004-01-11 by Antonis Ricos
Dave,
since you are already using OPM under OS 9 you would have some interesting choices
if you also used IJC and made your own profiles.
Some of the reasons to use UT inks:
- can be available in bulk if you need a CFS
- you can selectively use a UT gray of your choice to replace just a single color
position in the UC lineup. Useful if you like everything else but object to slight
dottiness in places where black begins, for example. Also makes it easier to restore
the printer back to color.
- A cool toner (of the UT set) available in 2 dilutions is more manageable dot-wise
than using pure cyan and magenta from the original inks (unless of course you like
your prints the original color of UC/UT black and grays).
Reasons to keep (some of) the UC inks:
- You can push to even warmer tones by using magenta and yellow. This is less trivial
than it seems - I have made prints using extreme sepia profiles that I liked a lot.
The nice thing about the 2200 is you can mix and match. One caveat, though: while
the Epson OEM carts have a proprietary valve that allows them to be removed and
replaced without damage, the aftermarket ones don't. If you remove them before they
are empty you pretty much give up on using the remaining ink.
As for which inkset produces the deepest black and on what papers, I don't have my
own data, but I doubt there will be a significant difference. I know Paul has done the
homework; you may search the archives for that. Just keep in mind that IJC would give
you ways to maximize the capabilities of the black ink by allowing you to minimize
what other inks may also hit the deep black end of the scale.
Antonis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dave08g" <dave08g@y...>
2004-01-11 by dave08g
Antonis,
Thanks for your help.  I have considered buying the IJC SW but have
held off because I have to close OPM and re-open it after each time I
print or it crashes and I have to re-start my MAC.  And I'm
procrastinating whether to buy OSX in which case I might try QTR first
before buying IJC.
But I do like your idea of selectively using UT gray.  I can see more
smoothness with prints made with the Epson driver than with OPM and 2
UC inks.  I just hate the color shifts and metamerism.  And I am doing
just enough color work right now for it to be a bit of a hassle to
switch back and forth.
I'm curious as to how much 2200 UT ink business MIS will get with
OPM/IJC and QTR being the only solutions available right now for the
2200.  And both of these seem to require more advanced skills to use
them.
At some point, I may just keep the 2200 for color and buy a 1280 for
b/w and use UT - it seems like a simpler path.
It seems to me that if Epson could only come out with a couple more
gray inks that could be substituted for color positions (and the
driver modified to support it) it could potentially eliminate the need
for anyone to use 3rd party inks on the 2200 (or on a second printer
dedicated to b/w).  But everyone knows that'll never happen.
Thanks again,
Dave Gordon
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Antonis Ricos"
<antonisphoto@y...> wrote:
> Dave,
interesting choices
single color
object to slight
easier to restore
manageable dot-wise
course you like
I liked a lot.
though: while
removed and
them before they
don't have my
Paul has done the
that IJC would give
you to minimize
Dave,
Sorry to hear that. OPM hasn't behaved like that on my machines, so I imagine it's
other issues like memory, extensions etc. Would be worth reporting to bowhaus,
though they are now putting all their efforts to completing the OS X version.
You sound like an ideal candidate for ImagePrint, though I guess that means moving
to OS X.
Having both, I think this is by far the better way to go. The 1280 will seem a bit slow
if you are used to the 2200, but it's a cheaper option to a second 2200. Also - you'll
have to decide on a CIS vs carts. The latter can get expensive, the former will need
priming if it sits idle too long.
> gray inks
I wonder why not, sometimes. It's not like they don't know what we are doing with
their printers. By now they should be able to afford to throw a bone or two to niche
markets like ours.
Antonis
RE: [Digital BW] Re: 2200 and MIS UT inks/OPM
2004-01-12 by Paul Roark
>them.
The 2200 is next up for the UT2 inkset.  (The loaner I'm going to use is so
full of waste ink, however, that it's probably going to have to be serviced
before it's shipped.)  I hope to have the UT2 inkset and 2200 going in a
month or so.
