Photo Rag replacement
2004-01-11 by Roger Smith
DigitalBlackandWhiteThePrint@yahoogroups.comRBSmih1/10/04 7:20
PM1/03/2004DigitalBlackandWhiteThePrint@yahoogroups.comrbsmith252@...
t
> Message: 22
> Date: Sat, 10 Jan 2004 23:22:02 -0000
> From: "alexfuchs" <alexfuchs@...>
> Subject: H Photo Rag
> Hahnemuele is famous for selling private label its papers to
> resellers/retailers for rebranding.  Does anyone know if this H.
> Photo Rag 308 is sold under any other brand name?
> Thanks in advance.
> -AJF
Lyson 310 Standard Fine Art Paper - It has a better price, comes packed in a
box and is less expensive at Photofile, 466 Central Ave, Northfield, Il
60093-3041.  Phone: 847-441-5450.  I print this paper on a Epson 1200 with
Fotonic Inks using exactly the same profile as the Hahnemuele Photo Rag
(profiles for most printers are provided by Lyson and seem to be fairly
accurate) I've been very happy with the results and the savings.  It is sold
in boxes of 50 sheets.
Roger Smith
E. Lansing, MI 48823
Re: Photo Rag replacement/Lyson
2004-01-11 by Antonis Ricos
While it is true that Hahnemuhle makes the Lyson papers, please note that the coating
is meant for Lyson inks only. It is intended to be compatible with the acid
requirements of dyes.
I don't believe there are any fade tests to reasure us that it is OK to use Lyson-coated
papers for pigment inks such as Piezotones, UT, UC etc. Use
at your own risk.
That said, it's worth noting that the Lyson dyes are capable of deep black on matte
Lyson papers and better compatibility with glossy-type papers than pigment inks.
Just because they are dyes, it may not mean that they are inferior to pigments in
archival stability (assuming they are used on their "own" papers). If anyone knows of a
direct comparison of fade reistance between Lyson and the current pigment
champions, please post.
Antonis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Roger Smith
<rbsmith252@c...> wrote:
> DigitalBlackandWhiteThePrint@y.../10/04 7:20
> PM1/03/2004DigitalBlackandWhiteThePrint@y...@...
> t
> > Message: 22
> > From: "alexfuchs" <alexfuchs@y...>
> > Thanks in advance.
> > -AJF
> Roger Smith
