I use QTR and the learning curve is very short, particually with the
latest release.
ImagePrint has "hidden costs" if you do not subscribe to their $500
per annum customer support program you will not get any free upgrades
beyond a few months. For example they are going to release a new
version any time. If you purchased a few months ago and did not pay
the $500 per year you will not get the upgrade for free. Not a great
policy in my view. It does work on windows of course, but you can
purchase a pretty good mac system for less and have some pretty good
hardware to boot. I use a Pismo laptop for QTR and its very nice,
great for my Ipod too.
Sierra Gold--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "Antonis Ricos"
<antonisphoto@y...> wrote:
> > Imageprint? Septone? QTR? MIS inks? What??
> Easiest out of the box, but most money is ImagePrint. Will also
improve your color
> use of the 2200. Downside: you can't tweak the bw ink mix past what
is built in, or
> make your own profiles. Many people are very happy with the
results, though.
> Zero cost, but some learning would be QTR. If you are on OS X that
is likely your
> cheapest option. I'd say, why not start from there and spend money
only if you feel
> you need to explore other options.
> Also zero cost, but OS 9 (also runs on Classic) is OPM. You can
explore that option by
> going to
> http://www.bowhaus.com/inkjetcontrol/
> This is basically last year's model, but gives you an idea of
what's in store when the
> OS X version comes out this year. The companion IJC software, which
makes profiles
> for OPM costs under $200. Unless you get a promise of a free
upgrade to the new
> version, however, it's not worth buying the old one. Among other
things the new
> version has ways of making bw profiles that are much easier than
the OS 9 version.
> Unless you have a second printer to devote to bw (which is ideal),
you'd want to stay
> with the OEM inks on the 2200.
> Generally speaking, the ideal scenario is a printer dedicated to bw
(i.e. using UT or
> Piezo inks) and software that allows you to make your own profiles.
The more control
> you gain on the process, however, the more you have to be prepared
to learn and the
> less "plug-n-play" the solution will be.
> Antonis
