Wax coat for glassless framing - Renaissance - crosspost
2004-01-14 by Tom Andrews
Hi, I just tried out some Renaissance wax as a final coat on Epson Premium Luster paper. It seems to work really well, giving an almost invisible finish to the print. I rubbed it on the print with a cotton cloth and then buffed lightly with another. Dries very fast and becomes quite hard - won't show finger prints. I also tried putting it on after spraying the print with Premium Art Print Shield and it goes on even easier and smoother. I am planning to try out this combination on large 32x40 and 40x50 prints mounted on gatorfoam or dibond and framed without glass. I'm still a little worried about how durable this combo will be and about how it will affect the longevity of my pigment ink (10K) prints. However, the blurb from Renaissance (sold by Light Impressions for $19.95/8oz) says that it is acid-free, developed for preservation use, and used by museums on the surface of fiber-based silver photographic prints. I also tried it on Photorag for the hell of it - turns the image to soft mush. I'm hoping that this is the solution to my quest for glassless framing. If not I may use another spray such as Liquetex. What I like about the Print Shield/Wax combo is that it gives a surface that is relatively indistinguishable from the untreated print. I haven't tried it on Epson Premium Semimatte yet. I just ordered a roll and printed on it for the first time using my custom profile for Luster and can't easily tell the difference between it and Luster, except the semimatte is very smooth and the Luster has a very fine pebbly texture when viewed in certain light. I wish it came in sheets as well as rolls. Cheers, Tom Andrews http://www.wildlandart.com
