UT2 Review on Semigloss/Glossy Papers
2004-01-17 by dirkhobman
For those who might be interested, I have spent several weeks using the new UT2 inks from MIS on semigloss papers. The following is a preliminary (potentially overly thorough!) review and may prove helpful for others who are interested in printing on glossy or semigloss papers with this inkset. For reference, I have been using the UT2 inks on a 1280 printer on which I previously used the original Ultratone inks. Comments are as follows: Given proper driver settings, the puddling problem of the original UT inks on some glossy papers has been almost entirely eliminated with the UT2 inks. These inks even seem to work well on Kodak Ultima Satin photo paper, which I found exhibited disastrous puddling problems above all other glossy papers (a dubious honor indeed). The new UT2 set completely eliminates not only the problem of puddling but also the problem of excessively warm shadows on glossy papers which plagued the original UT inks. Additionally, I printed without curves and can see that these inks will work well for beginners and allow them to bypass the use of curves. This is obviously an important feature. In terms of toning ability, I believe the UT2 inks surpass the Ultratones, especially in terms of ease of use. Since I have always been more interested in printing on glossy rather than matte papers, I focused my efforts again in this area. I began by testing the inks on Epson Professional Glossy Paper and then ran comparisons with Epson Premium Semigloss and Epson Premium Luster paper. First and foremost, I should stress that unlike the original Ultratones, I believe the new UT2 inks will allow for printing on just about any glossy or semigloss paper in existence. This is outstanding! I have been communicating my impressions about the UT2 inks with Paul, and he (as always!) offered me invaluable assistance and advice. Following are the many observations I have noted with the new inks: 1) Though the UT2 inks were designed for ease of use, and though they can be used without curves, I find that curves still provide the best form of control and will probably be desired by more serious users. Curves are still unbeatable when it comes to making the finest prints. In this respect, the UT2 inks are superb; they are easy enough for beginners to use but still allow advanced users to exercise the utmost degree of control. 2) Customizing curves with the UT2 inks is significantly easier than customizing curves with the original Ultratones. Changing the degree of toning of any part of an image is quite straightforward in comparison to what was needed for the same effect with the original Ultratones. 3) I still find that glossy papers benefit from setting the Epson 1280 driver at 2880 dpi. I printed a grayscale wedge at 1440 dpi and saw the puddling problem I had had with the original UTs. This problem occurs primarily around 80% on a grayscale test file. It was greatly diminished, but there nonetheless. At 2880 dpi, this disappears almost completely. This finding may stand in contrast to what Paul has found. I noticed problems printing at 1440 dpi, whereas he doesn't seem to have this. It is possible that this is an environmental response, as the very dry air in Colorado where I live has caused problems for me in the past that others haven't necessarily noticed. Regardless, the important point is that there is a remedy to the problem should other users encounter it. 4) At one point in our communications, Paul mentioned that there was a slight problem with shadows being a bit too magenta on glossy paper. At the time, I hadn't quite understood this. I had only printed on the Epson Professional Glossy Paper up to that point. However, when I started using the Epson Premium Semigloss paper, I did indeed notice the magenta cast in the shadows. This cast doesn't exist on the Epson Professional Glossy Paper. I note this only as an observation. Having now made quite a few prints on Epson Premium Semigloss Paper, I can say that the cast is essentially unnoticable. I do not anticipate that this will be a problem of any significance. It is really only noticeable when looking at a greyscale wedge, and even then it is fairly subtle. 5) I made new curves for Epson Professional Glossy Paper using the Epson driver set for Photo Quality Glossy Film at 2880 dpi. The resulting grayscale is incredibly smooth. However, with the UT2 inks, I saw a drop in dmax as compared to the original Ultratones. I then changed the driver to Photo Paper (2880 dpi). The dmax jumped dramatically, but then the mottling problem that I have described in the past returned (it is evident from 75% through 85%). After experimenting with the Epson Premium Semigloss and Luster paper, I believe this problem is particularly pronounced with the Professional Glossy Paper. The Epson Premium Semigloss and Luster papers can use curves that print with the driver set for Photo Paper and achieve a dmax of well over 2.0 with far fewer mottling problems. Ultimately there seems to be a tradeoff between using the driver set for Photo Paper versus Photo Quality Glossy Film. Photo Quality Glossy Film provides ultimate smoothness at the expense of dmax. I have not really been able to decide which setting I prefer at this point, though I think most users will find the Photo Paper setting to be preferable. I should emphasize that any mottling I am seeing is VERY subtle, and that I don't think it would even be noticable in the vast majority of images. 6) In terms of semigloss papers, I think users would do well to start with Epson Premium Semigloss. That paper with the UT2 inks makes an incredible combination, and one that should exhibit superior longevity. The dmax is outstanding. Bronzing and reflectance issues are somewhat more noticable than with a paper like Epson Professional Glossy Paper, but not enough so to merit losing the archival benefits and high dmax of the Premium Semigloss. Epson Premium Luster is comparable to the Premium Semigloss, though it has a more textured surface. Curves for the UT2 inks that work on the semigloss work equally well on the luster paper. On the upside, the Premium Luster paper has more available sizes in the US. This is really only a consideration for users with paper needs extending beyond 13x19. When Epson releases the 4000 printer, users may find themselves switching to Epson Premium Semimatte paper, as it will be released in sizes specifically for that printer. I unfortunately have no experience with that particular paper. 7) Glossy prints still benefit from the use of an overspray such as PremierArt spray. Such a spray, while not mandatory, can reduce or eliminate reflectance and bronzing issues. PremierArt spray in particular seems to aid in print longevity. 8) I have experienced no clogging issues with the UT2 inks. This, despite a very dry environment. I have only used the inks in individually filled cartridges so cannot comment on how they might react with a CFS. These are my specific observations thus far. In conclusion, I find the UT2 inks to be outstanding. I do not see myself returning to use of the original Ultratone inks on the 1280 printer given the obvious advantages of the UT2 set. If you have been restricting yourself to matte paper printing, I would suggest giving the new UT2 inks a try on a glossy or semigloss paper of your choice. I think you'll be pleased with the results! Dirk Hobman
