Grain reduction
2004-01-24 by marcsien77
I would greatly appreciate advice on a PS technique to reduce grain from an almost uniform overcast sky area of a BW image. The rest of the image is fine so I was thinking of doing something with a layer mask but so far I had no luck. Many thanks in advance, Marc.
2004-01-24 by bwinkjet
Hi, Copy the background layer, magic wand the sky, contract it 1-2 pixels and run Blur-degauss at about 3 and see if that works. If you need less, then reduce the opacity in layers. Hope this helps. Paul --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "marcsien77" <marcsien77@y...> wrote: > I would greatly appreciate advice on a PS technique to reduce grain > from an almost uniform overcast sky area of a BW image. The rest of > the image is fine so I was thinking of doing something with a layer > mask but so far I had no luck. Many thanks in advance, Marc.
2004-01-24 by Victor Landweber
You may want to try a dedicated noise-and-grain-reduction plug-in. "Neat Image" works great for grain reduction. It's available at several price points, with the Pro version providing Photoshop plug-in functionality. I prefer it to "Grain Surgery", "Quantum Mechanic Pro", or "Applied Science Fiction Digital GEM" (great names, eh?) after having tested all four. Very effective grain reduction, very controllable, works great on black-and-white images, and the latest version works more quickly than earlier versions. I also think its price is lower than the other programs (though I'm not sure). I usually duplicate a layer, run "Neat Image" and blend the grain-reduced layer with an unprocessed layer to visually adjust for the best compromise between grain reduction and the preservation of a certain photographic look. For a uniform area like your overcast sky, you may want to select the sky, feather the selection, and set "Neat Image" to almost entirely eliminate the grain. http://www.neatimage.com/index.html?v "Neat Image" is PC only, though I presume that someone probably publishes Mac software with similar functionality. Others may want to make Macintosh recommendations... At 01:32 PM 1/24/2004, marcsien77 wrote:
>I would greatly appreciate advice on a PS technique to reduce grain >from an almost uniform overcast sky area of a BW image. The rest of >the image is fine so I was thinking of doing something with a layer >mask but so far I had no luck. Many thanks in advance, Marc.
2004-01-24 by Paul D. DeRocco
> From: marcsien77 [mailto:marcsien77@...] > > I would greatly appreciate advice on a PS technique to reduce grain > from an almost uniform overcast sky area of a BW image. The rest of > the image is fine so I was thinking of doing something with a layer > mask but so far I had no luck. Many thanks in advance, Marc. I generally begin with Select->Color Range to select all the sky, then use other selection tools to get rid of any other pixels that may have been inadvertently selected. Then I blur it. I've found that Smart Blur works better than Gaussian Blur for one reason: even if you carefully select only the sky, the Gaussian Blur algorithm will pull in some of the color from the nearby pixels outside the selection area, which will discolor the edge of the sky. Smart Blur doesn't do this. Unfortunately, in PS CS, Smart Blur is one of the filters that they didn't get around to upgrading to 16 bits, and indeed in 8-bit mode it can reduce the noise so much that you wind up with visible posterization. Use sparingly. -- Ciao, Paul D. DeRocco Paul mailto:pderocco@...
2004-01-25 by MartyF2938@aol.com
> Grain reduction > > I use NeatImage on most of my digital images that will be printed as large > format. I find it does an invaluable job of reducing grain and noise, and is > easily controllable to give you the effects that you want. I believe you can > get a free trial version to test it out yourself. > [Non-text portions of this message have been removed]
2004-01-25 by Mark Hahn
Neat image is a great tool... I bought the plug-in version and find that it often works well with digital noise, but have been disapointed in its ability at grain reduction... I have had better luck just de-focusing my scanner and then carefully sharpeing... while this is just another filtering technique, it seems less tied to the theoretical blur using during unsharp masking and seems to give *me* better final results. ...that said, I think it is almost a hopeless task since you have to degrade your image so much to actually remove strong grain that you can't ever get back a sharp image... of course, if your grain is really tight, the image degradation is almost unnoticed... but than why bother... ...get the free version of NeatImage and see if it works for you. and, umm... don't know what you are running, but they still don't have a Mac version:( mark ... > > Grain reduction > > > > I use NeatImage on most of my digital images that will be printed as large > > format. I find it does an invaluable job of reducing grain and noise, and is > > easily controllable to give you the effects that you want. I believe you can
> > get a free trial version to test it out yourself. > > > > > > > [Non-text portions of this message have been removed]
for skies, a median filter is sometimes appropriate... mark --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul D. DeRocco" <pderocco@i...> wrote: > > From: marcsien77 [mailto:marcsien77@y...] > > > > I would greatly appreciate advice on a PS technique to reduce grain > > from an almost uniform overcast sky area of a BW image. The rest of > > the image is fine so I was thinking of doing something with a layer > > mask but so far I had no luck. Many thanks in advance, Marc. > > I generally begin with Select->Color Range to select all the sky, then use > other selection tools to get rid of any other pixels that may have been > inadvertently selected. Then I blur it. I've found that Smart Blur works > better than Gaussian Blur for one reason: even if you carefully select only > the sky, the Gaussian Blur algorithm will pull in some of the color from the > nearby pixels outside the selection area, which will discolor the edge of > the sky. Smart Blur doesn't do this. Unfortunately, in PS CS, Smart Blur is > one of the filters that they didn't get around to upgrading to 16 bits, and > indeed in 8-bit mode it can reduce the noise so much that you wind up with
> visible posterization. Use sparingly. > > -- > > Ciao, Paul D. DeRocco > Paul mailto:pderocco@i...
2004-01-26 by Jan Becket
Hope this isn't off-group, but here's another way to deal with the problem: go to a larger format film and use something like T-Max 100 or even Tech Pan. I found developing T-Max in Pyro works great for scanning negs that may also need to be printed in the old wet way. There is a huge grain difference between my 4X5 neg scans and the 6X9 ones I took on a trip this summer, and there is no way to make the 6X9 ones look like the 4X5 ones, unfortunately. Jan B. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "marcsien77" <marcsien77@y...> wrote:
2004-01-26 by Mark Hahn
don't know that it is off-group, but it is of course the real answer! mark --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jan Becket" <jbecket@l...> wrote: > Hope this isn't off-group, but here's another way to deal with the problem: go to a > larger format film and use something like T-Max 100 or even Tech Pan. I found > developing T-Max in Pyro works great for scanning negs that may also need to be > printed in the old wet way. There is a huge grain difference between my 4X5 neg > scans and the 6X9 ones I took on a trip this summer, and there is no way to make the > 6X9 ones look like the 4X5 ones, unfortunately. > > Jan B. > > > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "marcsien77" > <marcsien77@y...> wrote: > > I would greatly appreciate advice on a PS technique to reduce grain > > from an almost uniform overcast sky area of a BW image. The rest of > > the image is fine so I was thinking of doing something with a layer > > mask but so far I had no luck. Many thanks in advance, Marc.
2004-01-26 by B. Alex Pettit Jr.
Marc, Download a demo copy of PictureWindowsPro and try the gaussian blur. Create a mask which avoids getting too close to objects needing to be maintained sharp. GaussianBlurr 5 - 15 pixels but apply only a small percentage... open a preview window and magnifiy to watch the results. If you can create a mask which does not cause blurring of the other part of the photo, sky and clouds look excellent with quite a bit of 'defocusing'. PicWinPro uses 16 bit operations for all functions Good Luck, Alex --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "marcsien77" <marcsien77@y...> wrote:
2004-05-04 by Barbara White
Perhaps a dumb question, but - can I just add a new bottle of FS black in my CIS to my old bottle of FS black (before Eboni) - or do I have to get new cartridges and clean out the hoses before I do this? Can't seem to get a simple answer from MIS. Thanks, Barbara White barbara@... http://www.worldartphotographs.com
Perhaps a dumb question, but - can I just add a new bottle of FS black in my CIS to my old bottle of FS black (before Eboni) - or do I have to get new cartridges and clean out the hoses before I do this? Can't seem to get a simple answer from MIS. Thanks, Barbara White barbara@... http://www.worldartphotographs.com barbara@... www.barbarawhitephoto.com www.worldartphotographs.com
2004-05-04 by Paul Roark
Barbara, >... can I just add a new bottle of FS black >in my CIS to my old bottle of FS black (before Eboni) - or do I have to >get new cartridges and clean out the hoses before I do this? Can't seem >to get a simple answer from MIS. Don't mix Eboni with the old FS black. Eboni is very sensitive to all sorts of things, including dyes. All the old blacks had small amounts of dye in them to get an acceptable dmax. So, if the new FS K is Eboni (and I think it is), I would not mix it into the old FS K bottle. (By the way, I still have some of the old FS/VM K, including and un-opened pint bottle, if someone wants some.) Paul www.PaulRoark.com
2004-05-05 by donbga
Barbara, According to MIS the two inks are incompatible and the carts should be replaced. Good luck, Don Bryant --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Barbara White <barbara@b...> wrote: > Perhaps a dumb question, but - can I just add a new bottle of FS black > in my CIS to my old bottle of FS black (before Eboni) - or do I have to > get new cartridges and clean out the hoses before I do this? Can't seem
> to get a simple answer from MIS. > > Thanks, > Barbara White > barbara@b... > http://www.worldartphotographs.com
