Sanders,
>Paul, have you figured out yet whether the MIS UT-22 inkset will work with
>the 7600?
The new variant of UT2, which I think we'll start calling the UT2-2200 (as
opposed to UT2-1280), is working so well on the 2200 that I'm 99% sure it
will work on the 7600. I assume that the UltraChrome inks are the same for
all the Epson UC printers. As such, although there may be some driver
differences, I'd guess they are minor enough that the inks will work with
only minor changes in the curves.
I suspect MIS will be able to have the UT2-2200 in an "experimental" mode by
the end of the week. There are differences between the 2 variants of UT2,
so don't buy and load the UT2-1280.
For UT2 information and settings see:
http://home1.gte.net/res09aij/
