A single cartridge not printing with refilled 2100/2200 cartridges
2004-01-28 by dave_in_gva2001
I'm using UT-1 inks on an Epson 2100. I have a strange problem that I wonder if anyone else has experienced. I've refilled original Epson cartridges with the MIS inkset using the standard technique described on that very exhaustive website with all the colour pictures (don't have the link now). Afterwards, 6 of the 7 cartridges gave perfect nozzle checks with one cartridge (the light magenta position) refusing to lay down any ink at all. Head cleanings don't help, but uncrimping the filling tube and sucking out a little ink through the exit port using the bottom fill adapter followed by re-crimping the filling tube typically gives me a perfect nozzle check on this cartridge. After that I can print one, maybe two large prints before the nozzle check reverts to no ink being laid down again. When I replace this cartridge with an original Epson cartridge that hasn't been refilled the nozzle checks are fine, and stay fine, so the problem is with the cartridge. I've since prepared a second light magenta cartridge for refilling and have the identical problem - it's either perfect nozzle checks or no ink being laid down at all from that particular cartridge. My feeling is that it is almost like there is a vacuum within the cartridge that is holding back the ink and not allowing it to be laid down. I say this because when I introduce the bottom fill adapter when the cartridge is not laying ink down I initially feel a slight resistance when pulling back the syringe, and I draw out air from the cartridge, followed by a 'letting go' after which I get an ink stream re-established. As I say, after doing this the cartridge works fine, at least for a while, after which another air pocket or some kind of vacuum seems to form. It just seems a bit odd to me that I've had this problem with two light magenta cartridges now.........has anyone else had anything similar? I guess I'll just prepare a third but wanted to report here and see if anyone had ideas. Best regards, Dave
