785EPX and UT2
785EPX and UT2
2004-01-29 by mambo445
I am getting ready to buy some replacement inks.
Can someone tell me if UT2 will work on 785EPX? I am currently using
MIS/VM with Roark's 1280 Curves. The 785EPX ink cartridges are the
same as the 890.
Also, can I use old MIS/VM cartridges to fill UT2 inks? Thanks.
RE: [Digital BW] 785EPX and UT2
2004-01-30 by Paul Roark
>same as the 890.
If the 1280 VM curves work, then the UT2 might work.  I'm not familiar with
the printer, however.
No, start with a clean cart.
For UT2 information and settings see:
http://home1.gte.net/res09aij/
